Carb spacer question.
Old Sep 1, 2017 | 11:05 AM
eknight's Avatar
eknight
I recently bought a 71 F250 camper special. I found out it has a 1961 Thunderbird four barrel intake manifold and according to a friend o the holy on top of it was a ford version. I remove the holy and installed an Edelbrock performer 1406. Earlier pictures I posted someone noted that I had a spread bore to square bore adapter and that it may cause issues. So I have purchased a square bore 1 inch spacer. I'm wondering if it's even needed and if it is I have two ways to install it and I'm hoping someone with more experience could chime in with their thoughts. Should I use the four hole or the open insert? Or do I even need a spacer?
Old Sep 1, 2017 | 11:33 AM
HIO Silver's Avatar
HIO Silver
What you have there is a spread bore adapter for an open plenum manifold. The correct adapter should have been a 4-hole spread bore adapter. Just to note, a 4-hole square bore adapter is OK for use on an open intake plenum but not vice versa.
I suggest a 4-hole square bore adapter for your 4-hole square bore intake... one-inch max.
Old Sep 1, 2017 | 12:16 PM
JEFFFAFA's Avatar
JEFFFAFA
2X on the 4 hole. Open plenum is more suited for high RPM. 4 hole is better for off idle and low to midrange power and torque.
Old Sep 1, 2017 | 12:45 PM
eknight's Avatar
eknight
Ok. I'll switch over to the square adapter pictured using the 4 hole design. Is there any need for a spacer if my linkage works without? Also regarding jetting I'm hearing the extra space between carb and manifold might require larger jets.
Old Sep 1, 2017 | 01:24 PM
HIO Silver's Avatar
HIO Silver
My 70 (360FE/TKO) has a one-inch spacer and no mods to the linkage was necessary but it uses a Dentside linkage... no funky 'trapeze" set up anymore.
Yours should be okay.. the angle change isn't significant.
Old Sep 1, 2017 | 01:34 PM
JEFFFAFA's Avatar
JEFFFAFA
I don't think a 1" 4 hole spacer would require fatter jets. Headers and a high flow exhaust system yes. I don't have a 360/390 in my rig, but I've read on here numerous times that they like the spacers for more power. Spacers make the intake track from carb venturi to intake valve a bit longer. Which changes the power band. Mini version of a Tunnel ram intake or the 60's Chrysler Cross ram intake. To an extent, the longer the runner the higher away from idle the power band kicks in.
fordboy300
Dec 14, 2015 12:57 PM
farmall99
Jan 12, 2014 12:06 PM
68cabby
Aug 19, 2012 10:16 AM
RustyTrustyF150
Mar 18, 2006 01:37 AM
zsir
Aug 20, 2005 11:02 PM
