ignition switch actuator?
Old Sep 1, 2017 | 08:33 AM
mlavinder2's Avatar
mlavinder2
I have a 1987 F350 crew cab with tilt steering.It starts fine, but I have to hold the switch a litte forward for the radio ,wipers and power windows to work. It's like the key switch springs back too far and looses contact. I tried a new key switch, but it didn't change anything. Thanks in advance.
Old Sep 1, 2017 | 10:09 AM
My4Fordtrucks's Avatar
My4Fordtrucks
The ignition switch is further down on the column. It may need to be adjusted.
Old Sep 1, 2017 | 07:13 PM
mlavinder2's Avatar
mlavinder2
I'll have to do some research on doing that, hopefully that will do it. Thanks
Old Sep 1, 2017 | 07:28 PM
My4Fordtrucks
Is there a lot of play in the tilt column? That will contribute to the problem.
Old Sep 1, 2017 | 08:26 PM
mlavinder2's Avatar
mlavinder2
No play at all. Last winter the switch felt stiff when it was real cold. But I never had any issue until a week or so ago.
Old Sep 2, 2017 | 07:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
th eignition switch is located on top of the column, roughly above the brake pedal. it is held to the column by two 7/16 head bolts.
to adjust the switch, you need to loosen the two bolts a bit and slide the switch. there is about 3/8 inch adjustment available for the switch.
Old Sep 2, 2017 | 04:55 PM
mlavinder2's Avatar
mlavinder2
I'll give it a try tomorrow.
Old Sep 3, 2017 | 05:53 PM
mlavinder2's Avatar
mlavinder2
Not having any luck adjusting the switch, is there a trick to it? I tried down until the starter wouldn't engage, and up until it wouldn't disengag . No mater where, you still had to hold key switch forward for radio, power windows to work
Old Sep 3, 2017 | 05:57 PM
tjc transport
i ain't rite
did you feel or look at the switch to see if it is separated a bit? sometimes the switch will separate between the plastic and metal parts causing a no power unless the key is held just rite.
Old Sep 3, 2017 | 06:24 PM
White 97 xlt's Avatar
White 97 xlt
X2 It may be time to bite the bullet and replace the switch... It sounds like it has seen better days...
snowcrash47
Mar 13, 2012 11:29 AM
edf250
Sep 17, 2010 07:31 AM
RShape
Jul 12, 2009 07:23 PM
steetsel
1947 and Older Ford Trucks
Jan 31, 2004 03:58 PM
Franco1961
Dec 2, 2003 04:54 AM
