6 liter fuel problemq
Old Aug 31, 2017 | 08:55 PM
Tooley3's Avatar
Tooley3
Hi I have a 2006 F250 with a 6 liter diesel I got about a hundred sixty thousand miles on it I've had it bullet-proofed haven't had too many problems with it I thought the fuel pump went out yesterday so I replaced it drove fine for a few hours then it started losing power and like it wasn't getting fuel and died I got it home took a test light and check for power at the fuel pump I don't have any positive or negative power can someone please help me I ran a hot wire and a ground straight from the battery and hooked it up to the pump and it worked but when I plug the factory wiring back into it and turn the key on I don't have any power I checked the fuses they're fine
Old Sep 1, 2017 | 12:38 AM
r2millers's Avatar
r2millers
Check your fuel relay. They allow the fuel pump to start up for a few seconds. They flip off if they don't detect the engine running. They protect the pump from burning out if fuel isn't flowing through it. Not something that goes bad but very rarely but works with key power only.
Not a bad idea to changeout both fuel filters, knowing its recommended at about every 15k.
Old Sep 1, 2017 | 06:32 AM
Tooley3's Avatar
Tooley3
The first thing I did was changed to filters thinking that was the problem and when that didn't work I change the fuel pump thinking that was the problem I can't find the fuel pump relay when I have someone turn the key in the on position I get no power to the pump for some reason I don't have positive or negative but when I ran a wire directly from the battery negative and positive to the pump it works
Old Sep 1, 2017 | 07:13 AM
TooManyToys.'s Avatar
TooManyToys.
Unfortunately the relay is a non serviceable item that is part of the fuse box, a really stupid design about our trucks.
I would test first if running only positive to the pump works, letting the factory ground in place. That would separate a relay issue or a ground circuit issue. Someone who is really good with wiring could potentially wire in a replacement relay rather then replacement, but I'm not sure if in the end it's cost effective.
Old Sep 1, 2017 | 07:20 AM
navistarnut's Avatar
navistarnut
I thought it was #302 in the box under the hood?
Old Sep 1, 2017 | 07:39 AM
TooManyToys.
Late night, first cup. Let me go down to the computer.
Old Sep 1, 2017 | 08:05 AM
TooManyToys.
https://www.ford-trucks.com/forums/1...p-circuit.html
Cheezit, post 6.
Going down the stairs is a chore right now ......
leefarmfixer
30
Dec 28, 2015 08:13 PM
bigwill250
13
Oct 28, 2006 09:44 PM
mike_23us
1983 - 2012 Ranger & B-Series
Nov 26, 2005 11:13 PM
inlineguy
Electrical Systems/Wiring
Nov 23, 2003 10:07 PM
mattklionsky
Aug 4, 2001 01:17 PM
