Relays
Old Nov 23, 2003 | 04:07 PM
inlineguy's Avatar
inlineguy
Relays
Has anyone had any problems with there fuel pump relay or power realy on a 87-f150. Someone said this might be the reason why my truck is hard starting then wont run after about 20 mins of driving.
Old Nov 23, 2003 | 09:57 PM
Mike W's Avatar
Mike W
The easy way to check is to put a voltmeter or test light on the wire going to the fuel pump and see if you lose voltage when it quits.
Old Nov 23, 2003 | 10:07 PM
Franklin2's Avatar
Franklin2
They are prone to go out sometimes. A have heard of several that stick on, so when you park the truck, the fuel pump stays on and runs the battery down.
