Another CPS question
Old Aug 31, 2017 | 04:58 PM
BLUEMAX65's Avatar
BLUEMAX65
I have been burning up the search engine trying to find out if I have a bad CPS sensor.
When I start my truck the tach shows nothing no rpm shown at all till it starts. The other thing it does if the truck sits for more than a day it starts hard. It will fire up and die even if I hit the gas or fuel LOL. After that it cranks for a while and will finally fire up.
When it's warm it fires up but it does take at least seven cranks I would guess to fire up.
The ICP was replaced by the previous owner about three months ago and it is an OEM part.
Let me know what you think...
Old Aug 31, 2017 | 06:59 PM
F350-6's Avatar
F350-6
On 02 - 03 trucks the tach doesn't move until the engine fires. 01 and earlier 7.3's the tach would bounce.
Your description doesn't sound like a CPS issue. Sounds more like oil or injector issues.
Old Aug 31, 2017 | 07:43 PM
pirschwagon's Avatar
pirschwagon
You can easily rule out the CPS by Back Probing the wire on the CPS and connecting the Multimeter to Ground. CPS is either open or closed.
The speed at which it opens and closes is relevant to the rotational spin on the Engine. Low batteries will also contribute to a low rotational value.
CMP: high = 12 vdc, low = 1.5 volts
Old Sep 1, 2017 | 12:28 PM
BLUEMAX65's Avatar
BLUEMAX65
Well i guess the CPS is out of the question. Thinking the injectors are probably the problem. HPOP seems to be in a normal range.
john321
Jul 31, 2017 02:34 PM
hink10
44
Mar 12, 2011 11:48 AM
1969fordguy
May 12, 2008 02:45 PM
99powerstrokeSD
20
Jun 19, 2007 05:39 PM
Joe98684
Mar 9, 2006 04:11 PM
