Reese 16k
Old Aug 30, 2017 | 10:27 AM
1911fan's Avatar
1911fan
Reese 16k
I was wondering what you all do to stop the banging around that the pivoting head does when your not hooked up or is there something that locks the head in place that im missing?
Old Aug 30, 2017 | 11:29 AM
Bardeenm1!'s Avatar
Bardeenm1!
bungee cord from handle to tie down in truck bed.
Old Aug 30, 2017 | 11:57 AM
gasman6674's Avatar
gasman6674
Mine doesn't bang around much if any. Did you update the yellow bushings to the new style? That took a lot of movement and noise out of mine.
Old Aug 30, 2017 | 11:58 AM
1911fan's Avatar
1911fan
Thats what i already do just wondering if there was something better
Old Aug 30, 2017 | 12:37 PM
Bardeenm1!'s Avatar
Bardeenm1!
I will say mine doesn't bang around either but i do bungee when i put my tonneau cover on to keep the handle low even know I really don't need to.
Yellow bushings to new style?
You can also add rubber stops on all four corners of the base below the head.
Old Aug 30, 2017 | 12:53 PM
gasman6674's Avatar
gasman6674
Old "style" were a softer type material and new style are like suspension bushings
Top pic is new style bottom is the old ones which were pretty ovaled in the center
Old Aug 30, 2017 | 01:38 PM
akcooper9's Avatar
akcooper9
Do you have the part number? I tried googling the number in the picture and it did not bring anything up
Old Aug 30, 2017 | 02:37 PM
Bardeenm1!'s Avatar
Bardeenm1!
The pictures shown looks to be the titan?
Is your hitch in question a titan or standard 16k?
Old Aug 30, 2017 | 03:31 PM
1911fan's Avatar
1911fan
Regular el cheapo. Its what the rv place sold me with the camper
Old Aug 30, 2017 | 03:55 PM
gasman6674's Avatar
gasman6674
It is a Titan R16
I called Reese Customer service and told them my issue (excessive movement/noise) They ask for a picture of the bushing and then sent me the parts no charge
Old Aug 31, 2017 | 07:39 AM
Bardeenm1!'s Avatar
Bardeenm1!
On the base below the head is two rubber bump stops on the standard 16k. The base does have a spot to add another set so that all four corners have bump stops. I have seen people do this however I have not done it myself. This might quickly solve your problem.
Or let it rust that'll solve your problem also! Just kidding about the rust option!
300workhorse
Dec 15, 2009 05:49 AM
peter.jones
2009 - 2014 F150
May 5, 2009 08:17 PM
glasseater
Jun 7, 2007 06:28 PM
NMCam
Jun 5, 2002 08:28 PM
