2002 P0781 code now with shifting problems?
Old Nov 5, 2021 | 07:29 AM
mattm_'s Avatar
mattm_
Originally Posted by Mark Kovalsky
What year is your truck, and what engine?
The shifts are scheduled by pedal position vs. vehicle speed. If the VSS isn't working right there will be shift issues. FIx whatever is causing the P0500 code and see if the P08781 comes back.
2002 F250 with the 7.3 diesel. I'll try replacing the VSS since it's so cheap, but I have my doubts that will fix it because it looks like it reads fine on the FORScan feed. Could it be ABS module related? I'm not getting any ABS codes, but I did recently have mine replaced with a used but known good one.
Old Nov 6, 2021 | 08:25 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I have attached the VSS pinpoint test from the Ford Service Manual for your reference. If I recall correctly, the VSS is no longer available through the Motorcraft brand, so you may be forced to purchase an aftermarket sensor if that turns out to be the issue.
Typically the ABS module will set a code if there is an issue with the ABS. What caused you to replace the ABS module? A similar issue or something entirely different?
File Type: pdf
Old Nov 7, 2021 | 01:53 PM
mattm_'s Avatar
mattm_
Thanks for the test. I previously had the abs module replaced because the abs light was on and it was throwing an ABS code or two. I can look them up if you want, but the infi I found was that if the code I had appeared and another specific code was not present, then the issue was with the module. I took it to a mechanic for a diagnosis, and he found the same thing, replaced the module, and the codes went away.
Ty_Deschaine
Jun 14, 2017 07:10 AM
JustinAK5
Mar 26, 2015 06:55 PM
Txranger79
Feb 7, 2014 07:16 PM
John3366
May 27, 2011 08:56 AM
Mr_Superman
Jun 22, 2003 01:48 AM
