4R100 2-3 shift problem
Old Feb 3, 2014 | 05:07 AM
Txranger79's Avatar
Txranger79
I have an 04 Excursion v10 with 170K on odometer. I am having trouble with transmission shifting into 3rd. When I take off it shifts fine to 2nd, but it will not go into 3rd as it should. I can back off throttle and reaccelerate a coulple of times and then it will shift fine all day long. The OD light is not blinking but I did scan for codes and there is a soft code P1741 - there is no light on dash illuminated. Just wondering if this sounds like a valve body problem or shift solenoid. I am out of town and can't ohm test solenoids til I get home. Thanks
Old Feb 3, 2014 | 03:55 PM
Stewart_H's Avatar
Stewart_H
Looking at my OBD II code sheet shows the following information: P1741 - Torque Converter Clutch Solenoid Ctrl Error
Hopefully Mark K will chime in on your options and a direction for you to go.
Stewart
Old Feb 3, 2014 | 03:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That code has nothing to do with a 2-3 shift problem.
You could have a sticky shift solenoid, a sticky shift valve, or a failing direct clutch. If it is the clutch I would also expect delays shifting into reverse, as reverse also uses the direct clutch.
I doubt that checking resistance on the solenoids will tell you anything. If it is a bad solenoid it is mechanically sticking, the coil is probably fine.
Old Feb 7, 2014 | 10:30 AM
Txranger79's Avatar
Txranger79
Thank you Stewart and Mark for your replies. The chart I have shows P1714 to be related to Shift Solenoid A. I wasn't expecting the ohm test to really show me anything but figured I would at least start there, and you are correct - they tested fine.
Reverse is fine, no hesitation at all.
When I get back home I will look into more. We have parked it for now.
Old Feb 7, 2014 | 07:16 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Tons of the problems with the 4R100 are the feed bolts come loose and cause no shifts, poor shifts late shifts etc etc etc. I'd check them first and while you'll in there add new separator plate gaskets and a TransGo HD shift kit best $120 I ever spent on my F350 hands down
Sent from my iPhone using IB AutoGroup
Vettedrmr
18
Sep 30, 2023 11:00 PM
Idaho_F250
17
Nov 7, 2021 01:53 PM
Shadetrees
1997 - 2003 F150
15
Jun 3, 2015 10:57 AM
chris391
Oct 17, 2010 08:28 PM
Mr_Superman
Jun 22, 2003 01:48 AM
