Ford F-250: Why is My Transmission Shifting Too Hard?
Unless you're drag racing, a Super Duty that shifts hard is the sign of a problem. The root of the issue can sprout from a bad shifter cable, dying transmission solenoids, or just bad fluid. Use this guide to find the cause behind your F-250 Super Duty's misbehaving transmission.
By Brett Foote - November 17, 2014
This article applies to the Ford F-250, F-350 Super Duty (2005-2014).
Whether the problem comes from a sloppy shifter or a bad shift spring, these trucks are notorious for hard shifts. Many owners have given up in frustration or just had their entire transmission rebuilt, but we've got some handy steps and things to check that might just save you a bunch of money.
Tools Needed
  • Jack and jack stands
  • Wrench set
  • Socket set
  • T-25 Torx bit
  • Manifold gauge and line
  • 1/8" coupler
Step 1 - Check to see if your shifter is loose or sloppy
Many times, a hard shifting transmission is the result of loose or sloppy linkages that prevent the transmission from fully engaging into gear.
If the shifter doesn't line up correctly with the letter "D," the screws in the shifter mechanism might be loose. On top of the steering column there is a flange with two torx bolts that can be found if you move the shifter. Check to make sure those bolts are tight. Next, check the plastic adjusted located underneath the dash. By turning the wheel, you can make sure the selector pointer matches up with what gear you are currently in.
(Related Discussion - Gear Selector Lever Cable - F150online.com)
  • Figure 1. These bolts can loosen over time and should be tightened first.
If this doesn't fix your problem, move on to Step 2.
Step 2 - Check line pressure
Use a manifold or vacuum gauge attached to a hose and couple to measure the fluid pressure in your transmission. This "Line Pressure" test will determine if there are obstructions in the valve body of the transmission. Obstructions or broken components will cause the transmission to behave in unnatural ways.
If needed, jack up truck and place on jack stands. Remove transmission plug with a socket wrench and insert hose and gauge. Make sure wheels are chocked, engage four wheel drive, and lock the hubs. Start the truck and wait for it to come up to temperature. Test the pressure in park first, then through each gear. Check your manual to compare pressures and see if there is a problem. If you are seeing low pressures, it is an indicated that your pump is bad, the pressure control solenoid is bad, or the transmission filter needs to be cleaned. Here is an excellent video detailing the process.
(Related Article: How to Perform Transmission Line Pressure Test - Ford-Trucks.com)
Featured Video: How to Line Pressure Test Your Transmission - Ford-Trucks.com
Step 3 - Replace electronic pressure control solenoid
If the transmission filter is clean and the your problem is most likely a bad electronic pressure control solenoid (EPC). The EPC is the solenoid on the bottom left corner of the valve body. Replacing it is a multi-step process.
Unbolt, drain and remove transmission fluid pan. Pull off the transmission filter, and you should have access to the transmission's valve body. Remove the o-ring from the connector EPC connector. Use a screwdriver to lift the tab above the connector so that it can be turned and removed. Remove the screw holding the wiring harness in place and pull the harness out of the way. Pull the retaining clip off the solenoid, and slide the EPC out. Slide in the new EPC, replace the clip and harness, screw, and o-ring.
  • Figure 3. This is the EPC in a 4R7xx family of transmissions.
  • Figure 4. A diagram of solenoids for a 5R110 transmission.
Related Discussions
