Coolant leak
Old Aug 27, 2017 | 02:56 PM
ryan09's Avatar
ryan09
Coolant leak
I have a 2009 F150 and I have a coolant leak. I am positive it is not a cracked block or blown head gasket, had this checked by a mechanic already when I first bought it. It loses coolant without even driving it. I filled it up before bed one night and almost all was gone the next morning. Any ideas?
Old Aug 27, 2017 | 03:57 PM
Siberexpress's Avatar
Siberexpress
If you are talking about the coolant reservoir as the radiator cools it can suck it back into the motor/radiator. If it is parked on a hard surface is there any fluid on the ground below it? Oil over full or milky looking?
If you are sure it is loosing it you need to look for puddles, white smoke from the exhaust or something else like that. Look under the water pump and make sure the weep hole is dry and might try a new radiator cap.
Old Aug 27, 2017 | 06:05 PM
ryan09's Avatar
ryan09
Thanks
The answer to your first two questions is no, Nothing underneath and oil is same level as when it was changed. (about a couple hundred miles ago) No white smoke, but have not checked water pump. Thank you siberexpress
Old Aug 27, 2017 | 08:00 PM
xjcamaro89's Avatar
xjcamaro89
Check the aluminum block that the oil filter and oil cooler lines connect to. I just had the seals on this leak and replaced . I would loose coolant on the regular but I never had a puddle underneith because it would either burn off or the skid plate would catch it and it would dry up. But I could see it collecting into drips on the underside of that block . Mine was a '12 ecoboost so I'm not sure if yours is the same setup but worth a shot.
Old Aug 27, 2017 | 09:27 PM
ryan09's Avatar
ryan09
Thanks, I will check it out. I have an 09 4.6 V8 if you are wondering! more than likely will take to my mechanic though. Thank you anyway never thought of this
Old Aug 28, 2017 | 10:44 AM
rbentnail's Avatar
rbentnail
We in the motorcycling world routinely use baby powder, sprinkled liberally wherever we think a leak might be. They show up really well and the stuff washes off easily later.
Old Aug 28, 2017 | 07:44 PM
fastback89's Avatar
fastback89
I would pressure test it and let it sit overnight while pressurized. I've had success finding weird leaks that way.
Old Aug 31, 2017 | 09:55 AM
NorminN.B.'s Avatar
NorminN.B.
I had to replace a heater hose to metal tube on my 2009. The tube runs from under the intake, behind the alternater, to the rear of the engine and down the back of the engine. Hard to get at, but it rotted out at the bottom. I wonder if yours is leaking where it runs under the intake and pooling there. Just a thought. I replaced mine by bypassing the metal tube with heater hose, and running it out the front of the intake instead of the rear. The procedure is also on Youtube.
Old Aug 31, 2017 | 04:45 PM
ryan09's Avatar
ryan09
Pictures
Thanks to all that replied, I am going to post a picture in a little while of where I think it is so stay alert!
Old Aug 31, 2017 | 05:04 PM
ryan09's Avatar
ryan09
PICTURES
I think it is leaking To the left of the spark plug, where the radiator hose goes into the engine. But not sure im not an expert
Old Sep 1, 2017 | 06:13 PM
ryan09's Avatar
ryan09
Anyone
Anyone have ideas?
Old Sep 1, 2017 | 08:50 PM
zxwut?'s Avatar
zxwut?
A common 4.6 issue is the o-ring failing where the aluminum crossover meets the plastic manifold. It will puddle in the valley and spark plug wells. Something else to look into.
Old Sep 1, 2017 | 09:12 PM
ryan09's Avatar
ryan09
Is that something easy to replace? Is it cheap? Just wondering cause I'm kinda broke
Old Sep 4, 2017 | 12:24 PM
zxwut?'s Avatar
zxwut?
IF that's what's wrong with it, no. It's a few hundred dollars for the Motorcraft part. The Dorman part is much cheaper, but I hear it can have fitment issues. Make sure that's the problem first. Dry everything out well, top it off, and watch for where the leak is coming from.
granny_rocket
Aug 16, 2016 05:43 AM
mellowfe
Feb 23, 2011 05:56 AM
98FordTruck
Jan 15, 2009 06:31 PM
tm3912
May 12, 2006 08:11 AM
jharvey3
Jul 1, 2004 08:11 AM
