93 Explorer coolant problem
Old Jun 18, 2004 | 09:00 PM
jharvey3's Avatar
jharvey3
My '93 Explorer XLT has a coolant leak somewhere, the radiator is full but the overflow res is bone dry, also it's running hot, I can not find a leak anywhere but can smell coolant when I park it. What am I missing?
Thanks
John
Old Jun 18, 2004 | 10:51 PM
mrshorty's Avatar
mrshorty
Intake manifold gasket?
Or -- darest I say it -- head gasket? Any sign of coolant in the oil? Excessive white smoke out the exhaust? Figure that much out soon--you'll kill a motor quicker than prune juice through a skinny cowboy if you've got coolant in the oil. This is one case where I might recommend a coolant pressure test to find the leak.
Any idea how fast it leaks?
Old Jun 19, 2004 | 12:42 AM
vegasmailman's Avatar
vegasmailman
Had the same problem. Mine turned out to be the radiator. It was simple to replace and about $120. The leak was just slow enough that I could never see a puddle.
Old Jun 19, 2004 | 05:38 AM
jharvey3's Avatar
jharvey3
mrshorty and vegasmailman thanks for the replies, I apologise I was to frustrated last nite and didn't give enough info, here's what I've done....
New radiator, new water pump, new thermostat,no coolant in oil that I can tell, and no white smoke, pulled a spark plug on each side and no green on them. It leaks down fairly slow so I guess a pressure test is gonna be the best/only bet.
Thanks
John
Old Jun 19, 2004 | 11:18 AM
GrayRanger4x4's Avatar
GrayRanger4x4
The overflow res, is know to leal around the hose at the bottom of the tank.{Fords craper idea} look and see if the fender well is staned under the tank {bet it is } you found your slow leak.Also a bad cap will let the coolent flow back in to the tank and leak out ,so check your cap too.
Old Jun 19, 2004 | 04:48 PM
jharvey3's Avatar
jharvey3
Thanks GrayRanger4x4 I'll do that! Hope to see you in October
John
Old Jul 1, 2004 | 08:11 AM
mackedisto's Avatar
mackedisto
Did you figure out the problem? If so please lets us in on it. My 91 is doing the same thing. I add to it only about once a month. Thanks
