Sponsored by: Real Truck
6.0l overheating
Old Aug 26, 2017 | 03:24 PM
JAlbee's Avatar
JAlbee
6.0l overheating
I have recently purchased a used 2007 f359 6.0l powerstroke
We tried to leave town with it for the first time and upon claiming the hill it began to overheat.
I see no white smoke
No coolant on or around the degas bottle
And it's not low on coolant either .. once the hill is peaked the coolant temp returns back to normal and doesn't move until another pull is made.
It is all stock except for the turbo back exhaust system but the dealer didn't know anything about the truck.
It goes back on Monday to see what the issue may be but this is a mom and pop car lot so I'm not too sure of what they will be able to diagnose or fix
If anyone can give me some ideas on what may be causing this and how to further drag I would greatly appreciate it.
Old Aug 26, 2017 | 04:29 PM
T diesel's Avatar
T diesel
Water pump?
Old Aug 26, 2017 | 05:25 PM
FiznUKa's Avatar
FiznUKa
Check to make sure the fan is plugged in its located left of the upper radiator hose should be a four wire plug. Have you had the codes read? Do you have a way to monitor the engine Maybe with a scan gauge or torque pro. If not you best find one its hard to diagnose these engines with out one. What is the fluid level the min line is the full mark.
Old Aug 26, 2017 | 08:30 PM
speakerfritz's Avatar
speakerfritz
Get a new pressure csp
get a coolant tester for about 15 dollars and measure the coolant for the right ratio's
Old Aug 27, 2017 | 08:29 AM
sur48's Avatar
sur48
I would check what the other members have stated starting with a pressure check that will answer a few and i may add that check the radiator is bad? I dont know if you will get a code for this. Is egr clogged ?
There is a oil cooler that coolant runs thought under turbo on top of motor. This was clogged on my truck. I did not over heat but was missing a little coolant and it was vaporizing though cap . Crazy right
Old Aug 27, 2017 | 11:31 AM
DogRidesInBack's Avatar
DogRidesInBack
After the above, consider a thermostat stuck open.
Slow to heat up, and then overheats are typical symptoms of a thermostat stuck open.
Gettysburg150
Oct 28, 2014 03:04 PM
joejackF250
Jan 15, 2014 09:51 PM
outbackrat2001
19
Jan 7, 2013 11:21 AM
biggercb
1997 - 2003 F150
Nov 19, 2012 10:36 AM
wickymustang
Aug 25, 2004 11:32 AM
