Help with codes
Old Aug 26, 2017 | 12:58 PM
Chet j.'s Avatar
Chet j.
Help with codes
My 97 4.6 F150 keeps pulling these codes and not running well! Any help is appreciated in figuring out what i need to replace. P0305, P0113, P0171 both banks. Any ideas?
Old Aug 26, 2017 | 04:40 PM
Pocketlint's Avatar
Pocketlint
Ok if you read below it will tell you some of the possible reasons you are getting those codes and then that link will give you a little more indepth information
Before you go chucking parts at it. I would look to make sure you have no vacuum leaks. Make sure you trace the vacuum lines to each connection point on the engine, as you are following the lines make sure there are no breaks or holes in the line and at each point where there is an elbow or tee in the vacuum line make sure those fitting arent cracked or broken A vacuum leak can do all sorts of things to make a truck run rough.
Next thing I would do is check your air filter and make sure it is clean, if its dirty as hell time to change it. if it is okay, then I would go to your MAF sensor and pull it out and clean it. Do NOT use brake cleaner or carburetor cleaner to clean the MAF with you need to buy a cleaner that says it is for cleaning a MAF sensor, if you clean it with anything else you will ending up pooching it. After you clean the MAF let it dry for 15 or 20 minutes then put it back in.
While it is drying it is time for you to check your COP's ( Coil On Plug ) and see if they are good, while your at each cylinder have a look at the fuel injector electrical connection and make sure they are all attached and everything is good with the wiring ( no breaks or chafes) I would also while you are at each cylinder pull each spark plug and check your plugs ( when did you last change your spark plugs? ) repeat each step at each cylinder. A bad cop or spark plug will give you a misfire you need to check spark plug 5's cop and plug and the injector connection at 5 since that is a cylinder that is coming up as a misfire.
I would check those things first before you start chucking parts at it
P0305
Faulty spark plug 5
Clogged or faulty fuel injector 5
Faulty ignition coil 5
Fuel injector 5 harness is open or shorted
Fuel injector 5 circuit poor electrical connection
Ignition coil 5 harness is open or shorted
Ignition coil 5 circuit poor electrical connection
Insufficient cylinder 5 compression
Incorrect fuel pressure
Intake air leak
https://www.autocodes.com/p0305_ford.html
P0113
Faulty Intake Air Temperature (IAT) sensor
Dirty air filter
Intake Air Temperature (IAT) sensor harness is open or shorted
Intake Air Temperature (IAT) sensor circuit poor electrical connection
https://www.autocodes.com/p0113_ford.html
p0171
Intake air leaks
Faulty front heated oxygen sensor
Ignition misfiring
Faulty fuel injectors
Exhaust gas leaks
Lack of fuel
Faulty Mass Air Flow (MAF) sensor
Incorrect Positive Crankcase Ventilation (PCV) hose connection
https://www.autocodes.com/p0171_ford.html
Old Aug 28, 2017 | 01:27 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
Best practices say to address the codes from lowest to highest. Often once the problem that causing the lower codes to throw is fixed, the other codes go away as well, especially if they all appeared at once.
2003RangerJ
1983 - 2012 Ranger & B-Series
Oct 3, 2018 11:03 AM
awojtowicz
Mar 30, 2016 07:00 AM
Brian D'Ambrosio
Feb 6, 2014 11:21 AM
TommyBoy4.2L
1997 - 2003 F150
Mar 28, 2013 06:02 PM
fredo181
Modular V10 (6.8l)
Sep 15, 2009 10:08 AM
