Speed sensor from diff to trans
Old Aug 24, 2017 | 05:49 PM
Yblockmattmatt's Avatar
Yblockmattmatt
4wd Low
I own a 95 f150 with the stock 8.8 rear end. Ide like to upgrade to a 9in diff but the speed sensor for my truck is in the diff and I suck when it comes to wireing and electrical. I've heard that some of these trucks had the sensor in the tailshaft of the trans. I'm also needing to order a new trans for the truck. It's a beefed up e4od and they come with an option for the speed sensor to go in the trans. But I don't know what I need to do to make it work. Any experience with this at all.
Old Aug 24, 2017 | 06:23 PM
subford's Avatar
subford
If the transmission you get has the drive gear on the output shaft and the tail shaft housing has a place for it you can put a VSS in it from a F53 or and older pre 1992 trucks VSS.
You will need to reset the PSOM to a conversion constant of 1.0 (not easy done) then put a driven gear on the VSS to calibrate the speedometer.
Note the RABS will not work with the above set up.
Old Aug 24, 2017 | 06:26 PM
Eddiec1564's Avatar
Eddiec1564
The 95 speedometer(PSOM) looks for the 108 or 120 tooth tone wheel(depending on axle) that is inside the diff. The tail shaft VSS output mayl not give the correct pulse per mile the PSOM needs to calculate the speed.
I have seen others make up a tone wheel attached to the driveshaft and used the VSS sensor from the axle to drive the PSOM.
Old Aug 24, 2017 | 06:52 PM
rla2005's Avatar
rla2005
The only reason why the pulse count "may be" off is based on the drive and driven gear ratio for the VSS.
Personally I think a 9" rear axle is a downgrade. The Ford 8.8" has been proven to be plenty stout with the right parts. Unless you are looking for bragging rights, stick with the 8.8" rear axle.
Old Aug 24, 2017 | 07:41 PM
Mudsport96's Avatar
Mudsport96
I've seen an 8.8 live through clutch dumps with 38 inch thornbirds and go 8s in a 1000hp mustang. Forget the 9inch and just put a good posi unit in the 8.8 and since it's 20 plus years old treat it to new bearings and be done with it.
Old Aug 25, 2017 | 06:32 PM
Yblockmattmatt
4wd Low
Well after what I've read I guess I'll just stick with the 8.8. Thanks for the help guys guess I'll go with a posi
Old Aug 25, 2017 | 08:35 PM
Mudsport96's Avatar
Mudsport96
Yeah a quality posi and you are set.
Here's proof the 8.8 is decently strong
71buickfreak
Jul 22, 2019 09:58 PM
gccch
2004 - 2008 F150
Apr 2, 2018 06:37 AM
MONAVIERONJON
Aug 10, 2016 06:32 PM
Iallwork
Oct 10, 2011 11:04 PM
snizzitch
Oct 19, 2001 05:01 PM
