Looking for a little help
Old Aug 22, 2017 | 07:23 PM
P Suckow's Avatar
P Suckow
I have a 02 ford explorer sport trac the overdrive is not working and I have fixed the wire in the steering column and the neutral safety switch and it still does not work. Any ideas of what it could be???
Old Aug 22, 2017 | 10:59 PM
shorod's Avatar
shorod
Does the OD Off light work properly when the OD On/Off button is pressed? Is it solid or does it flash?
-Rod
Old Aug 23, 2017 | 04:09 AM
P Suckow's Avatar
P Suckow
The OD light dose not do anything. No light at all when the on/off button is pushed.
Old Aug 23, 2017 | 06:45 AM
shorod's Avatar
shorod
Do you have a way to test the OD switch and wiring to make sure the switch and wiring opens and closes as it should? Also, do you know whether the OD in the transmission is working (default) and the only thing that doesn't work is you are not able to turn the OD off?
-Rod
Poncho450
Nov 4, 2014 06:28 AM
mcdavidson
Oct 8, 2014 02:24 PM
BombThreat
Aug 28, 2009 06:20 PM
Tony Gannon
Apr 6, 2008 07:17 PM
kill_them_all
Dec 24, 2004 03:58 PM
