How much does a 302 weigh?
Old Aug 21, 2017 | 06:25 PM
Nathan511's Avatar
Nathan511
ive seen a few different answer ranging from 450 to almost 600lbs. Trying to find the true weight with everything one it(AC compressor, alternator, smog pump, all the wiring, etc.) of a 302 that came out of a 95 f150. I have an engine hoist rated for 2 tons with the bar set all the way back and I would like to drop the engine and trans in together. I will be removing the radiator core support to do so.
Old Aug 21, 2017 | 09:32 PM
Glaser67's Avatar
Glaser67
With a lift rated at 2,000# I'm sure you would be just fine lifting the 302, all accessories, and tranny together at once. I've done the same myself. Good luck!
Old Aug 21, 2017 | 10:04 PM
Mudsport96's Avatar
Mudsport96
You will.be under 2k pounds. The thing you need to do is make sure the rolling path of the hoist is good and clear of debris. So it rolls smooth... The weight isn't the big issue, the momentum of everything when your wheel hits a ziptie and stops the picker but the engine wants to keep going is what gets you lol
Old Aug 21, 2017 | 10:13 PM
animator's Avatar
animator
Can't give you any weights, but a 2-ton lift is plenty to pull a 351 with a t5 still attached.
Old Aug 21, 2017 | 11:03 PM
Scndsin's Avatar
Scndsin
A 5.0 is from 425 to 465 depending on dress. Add 325-365 for an E4OD, 100 to 150, or less for any other trans.
I don't worry so much about the crane as much as the pin holding the hook on the crane.
Old Aug 22, 2017 | 03:19 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Well he said the lift is rated at 2 tons so that is 4,000#. I agree that he will be fine.
Old Aug 22, 2017 | 07:35 AM
jas88's Avatar
jas88
You better check what it is rated at with the bar all the way out. I have never been able to get the engine into the bay with the bar all the way back.
Old Aug 22, 2017 | 08:42 AM
Nathan511's Avatar
Nathan511
the issue I run into tho is with the bar set all the way back, the engine won't clear the bumper when I go to lower then engine into place. Do u think it would be fine at 1 ton setting?
Old Aug 22, 2017 | 12:14 PM
Mudsport96's Avatar
Mudsport96
You are already pulling the core support right? Pull the bumper to, it's like 6 bolts. That should give you the room.
DOUBLEF222
Dec 31, 2006 12:23 AM
70blue
1983 - 2012 Ranger & B-Series
Jul 18, 2006 05:29 PM
devoejl
Oct 22, 2004 09:13 AM
Woodsman_30350
May 1, 2004 12:50 AM
siphor84
Oct 3, 2003 01:34 PM
