Steering problems... please help!
Old Aug 21, 2017 | 02:22 PM
dakeddie's Avatar
dakeddie
The 2 of the 3 screws holding my steering box on just sheared off at the threads when I was pulling into my parking spot. My steering has been stiff only when turning left and only when going slow for a couple weeks now. I've seen many posts on this, it seems the steering gear is mostly to blame.
But how would a bad steering gear cause the bolts to break? It must be binding on the steering somewhere else, right?
When I first started getting the stiff steering, I really thought it was my u-joints, the left front started making noise when I'm in 4x4. But when I jacked up the wheel, I could turn the u-joint freely when the wheel was at full lock. After that, I decided I was going to order a Redhead steering box, but now I'm not sure!
Old Aug 21, 2017 | 03:52 PM
DieselDenny's Avatar
DieselDenny
Drop the box, you have to anyway.
Lift the front end and try to manually move the steering dropping one unit at a time and trying again. Unless it's freely moving.
If everything moves as it should, the box is the cause.
Denny (Index your steering wheel).
Old Aug 21, 2017 | 04:48 PM
dakeddie's Avatar
dakeddie
OK, I'll do that tonight and report back.
It doesn't make sense that it would be the box though, right? The pump is built into the box, so if the box had bound up, the screws would have broken from the torque I input into the steering wheel, and I don't think I'm that strong.
Old Aug 21, 2017 | 06:03 PM
DieselDenny
I don't think so. It shares the brakes as well. The box is served by the pump that serves both.
Change your fluid as well when you do this. There are a few great write ups on flushing the system. In here I believe it's Guzzles page.
The system by itself is strong, it has very little to do with input strength.
If it was bound up, you may have had road/trail debris in it or it was just time to go. Pretty common failure point.
It's early, I haven't had mine off yet but others have had alot more experience.
Take out the box and look in here after you check for free movement on the steering assy.
If I said it, sorry, make sure you index your steering wheel or get really good at holding your turn indicator.....lol
Denny
Old Aug 21, 2017 | 07:00 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
The pump is not built into the steering gear, it is just the box. The top plate cover of mine sheared one of the bolts off as I was doing a low speed turn of the wheel.
Old Aug 22, 2017 | 01:25 AM
retiredsparky's Avatar
retiredsparky
What if one of your ball joints was binding? That would cause a lot of stress.
Larry
Old Aug 23, 2017 | 02:26 PM
dakeddie's Avatar
dakeddie
Got the box off and discovered the problem. One of the mounting screws was broken from a long time ago it. I think my symptoms started when I had a flat front tire. The added load of turning that tire strained the remaining screws. So when I turned left, the steering box would hinge on those two screws, when turning right the box was supported by the frame. Over a couple weeks it got worse until it broke! Don't know how old that original screw failure is, but it was real rusty. I think it was from before I got the truck.
I checked the rest of the steering with the drag link off... there's no binding anywhere. My box has play in it, so I ordered a Redhead. Tie rod ends on the drag link aren't as tight as they should be... getting the whole assembly new.
Thanks for the help guys!
Tparkin99
18
Feb 13, 2022 06:28 AM
Rachel Moody
15
Jan 16, 2017 11:51 AM
brandon.edwards
Jan 31, 2013 08:04 AM
WYO92350
Nov 15, 2006 08:14 PM
ford351c
May 19, 2003 10:14 PM
