6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Which temp sensor?
Old Aug 18, 2017 | 03:54 PM
Rudiak's Avatar
Rudiak
Which temp sensor?
Does anyone know which temp sensor I need to change for a P40D code EGR TEMP SENSOR A CIRCUIT HIGH? I need sensor location and part number if possible. I am finding a lot of conflicting information. Any help would be greatly appreciated!
Old Aug 21, 2017 | 08:30 PM
DieselDenny's Avatar
DieselDenny
Need more info.
Are you deleted (DPF) (EGR) ?
Any tuner etc...
Give us history and recents and we'll see what we see.
Denny
Old Aug 21, 2017 | 09:27 PM
Rudiak's Avatar
Rudiak
Not deleted all stock. My research is telling me it's in the turbo up pipe passenger side I will remove wheel well liner and check. I think I found the right part number I will post it.
Old Aug 21, 2017 | 09:32 PM
Rudiak's Avatar
Rudiak
AP63471 EGR TEMP SENSOR.
Old Aug 21, 2017 | 09:36 PM
DieselDenny
Very fragile to remove. Use Kroil or PB blaster a day ahead of time to soften the heat/threads. 1 time deal if you throw a wrench and strip it.
Before you start with tools, spray of course a day ahead, but pull the connection on the harness, make sure it's sanitary and plug it back in. Disconnect your batteries for an hour and see if it returns. There are (I believe 3 other sensors down the line toward your dpf that play the same game.) I'm kinda new to the 6.4 but my 3rd was done (furthest away from turbo on the exhaust (EGT) and I had the same fault.
Denny
rtaylor6801
3.7, 3.5 and 3.0 Duratec V6
Sep 28, 2017 06:50 PM
SPL Tech
Feb 7, 2007 12:44 PM
g0ldrush
Sep 19, 2004 03:43 PM
