Air charge temp sensor?
Old Sep 18, 2004 | 09:39 PM
g0ldrush's Avatar
g0ldrush
Can a air charge temp sensor could make the engine hard to start or in the first 5 sec of styarting engine stumble and black smoke and after these seconds the fast idle comes on and then engine warm up ok idles ok too
Old Sep 18, 2004 | 09:53 PM
g0ldrush's Avatar
g0ldrush
Its a 1989 ford e150 5.,0 liter
Old Sep 18, 2004 | 10:30 PM
pfogle's Avatar
pfogle
That sounds more like an 02 sensor.. I'd pull the codes on it for sure..... And then see what it says, it could also be an EGR problem.
Old Sep 19, 2004 | 12:07 AM
g0ldrush's Avatar
g0ldrush
I get a code 21 and 33 I change the egr valve and the sensor that goes over it I change the oxygen sensor too The only sensor I didnt change is the air temp one
http://www.goingfaster.com/spo/elect...ement_sys.html
Old Sep 19, 2004 | 03:45 AM
tdister's Avatar
tdister
doesn't sound like th O2 or IAT (don't these only/mostly matter after the truck warms up?). You may want to check the IAC. I have had dirty ones create similar problems, just be careful claening it if they are like most (are they sensitive to movement anyone?)
Old Sep 19, 2004 | 11:23 AM
g0ldrush's Avatar
g0ldrush
Hi again I change my IAC got onr from the scrap yard seems to work ok but I will see tomoorow morning on the first start of the day hope it,s that part heheheh see you
Old Sep 19, 2004 | 03:43 PM
Leo_T's Avatar
Leo_T
I just changed the IAT in my '96, 5.8L. The only reason I changed it was because the MIL light was on. I didn' notice any differance in the way it ran. I bought a scanner, and pulled a P0113. Ford calls it an air charge temp sensor. Ford wanted $37. for a new one. Seems like a fair price.
handsofpower
20
May 16, 2022 08:11 PM
Mikes '66
Jan 9, 2017 08:47 PM
Glenn.b1
Nov 10, 2015 10:13 AM
alie-r
13
Jun 5, 2012 01:50 PM
delano79
Aug 30, 2011 08:36 PM
