Ref cab to crew cab
Old Aug 17, 2017 | 07:21 PM
Tmarkh's Avatar
Tmarkh
Ref cab to crew cab
Does anyone know if it would be possible on a long-wheel base f150 (1983) to remove the bed AND regular cab and put a crew cab in its place? I saw a thread in 1999 about an f250 that did that and just made a flat bed (rather, they said that it was in a magazine from 1998).
Thanks
Mark
Old Aug 17, 2017 | 07:42 PM
FuzzFace2's Avatar
FuzzFace2
Think this has been brought up before and IIRC the answer is no.
It is because the frame turns up just behind the cab.
So if you put a longer cab on a short frame the rear of the cab will hit the frame.
Dave ----
Old Aug 17, 2017 | 08:25 PM
Nothing Special's Avatar
Nothing Special
... and as soon as you say it can't be done someone will say they've done it and it works fine. But yes, Dave is right, that the frame turns up behind the cab.
To do it you either have to do about a 3" body lift (and body lifts are no where near as easy as they seem, and 3" is a LOT) or else you need to channel the body to let the frame come up through the floor (and then deal with the big holes in the floor and how to mount the seat).
So it can be done, but it's a BIG job, that would be hard to do well and easy to screw up.
macman85602
Mar 24, 2008 01:25 AM
oldblue31
Jun 10, 2004 09:10 PM
joncaudill
Jan 31, 2004 05:47 PM
Scot
Apr 16, 2002 10:42 PM
Franklin2
Jun 28, 2001 02:16 PM
