Quad cab on standard cab chassis
Old Feb 16, 2008 | 07:43 PM
macman85602's Avatar
macman85602
Hello.
I have a question is there a way to mount the cab off of a 4 door on the chassis from a standard cab 2 door. i was thinking it would make a cool retro sport truck Just a thought...
Scott
Old Mar 22, 2008 | 06:50 PM
ford_boy_1996's Avatar
ford_boy_1996
Yeah I did it with a 79 ford You have to take the crossmember out of the 4dr frame its the one at the back of the cab. You would also have to make bed around 5ft long.
Old Mar 22, 2008 | 07:59 PM
Franklin2's Avatar
Franklin2
You may have to put a body lift on it to avoid the frame kick-up behind the cab.
Old Mar 23, 2008 | 08:52 PM
lostin90s's Avatar
lostin90s
Yah body lift or extend the frame about 3 ft under cab . There r 3 other post about this around. Look em up and get some Ideas.
Old Mar 24, 2008 | 01:25 AM
macman85602
I was thinking about using an extended cab frame but the short frame would give the short short bed i was thinking about. not sure about the cab mounts but i think moving the rear mounts would allow the cab to be mounted to the frame. Another thought i had was to mount the cab and find a bronco and mount that to the back end. I know there was a company that built a 4 door bronco. but home made is more fun. i am also thinking 3/4ton 6.9 diesel w/ 5spd. i know the body would take a large amount of cutting and welding. but it would be cool to say "i did that". scott
