Start Stop
Old Aug 26, 2017 | 01:04 PM
  #46
storage_man's Avatar
storage_man
Originally Posted by PupnDuck
Here's the list from the service manual of when the start/stop system WON'T operate:
The Auto-start-stop system may not turn the engine off under these conditions:
  • the HVAC system is in A/C, heat or defrost modes.
  • the rear defroster is on.
  • the battery has a low state of charge.
  • the battery temperature is below 5°C (41°F) or above 60°C (140°F).
  • the engine temperature is below 46°C (115°F).
  • the engine temperature is below 60°C (140°F) and the HVAC system is in heat mode.
  • the gear selector is not in Drive or Sport Mode.
  • the steering wheel is turned rapidly or is at a sharp angle.
  • vehicle speed of greater than 4 km/h (2.5 mph) for more than 2 seconds has not occurred.
  • the vehicle is on a steep road grade.
  • elevation is approximately above 3,048 meters (10,000 feet).
There are probably others.
My AC system is almost NEVER off. There is probably January and maybe a bit of February, but the rest of the time its on. Welcome to the desert !
Old Aug 26, 2017 | 03:20 PM
  #47
mikemtn's Avatar
mikemtn
You do know that we're not referring to the AC being turned off. I doubt that your AC compressor never stops compressing.
Old Aug 29, 2017 | 11:28 AM
  #48
BII Plow Truck's Avatar
BII Plow Truck
I'd love to see a tare down of one of these stop/start engines after 100k, and see what all those dry starts do. (Especially guys who don't use a full synthetic motor oil, I see bad engines after the powertrain warranty expires). I doubt Ford changed to an electric oil pump.
In addition, I wonder how many EcoBoost turbos will fail by shutting off the engine before the turbo can cool off and spin down......which is literally minutes before the shaft stops spinning.
Old Aug 29, 2017 | 05:24 PM
  #49
storage_man
Well after 4 days and about 80 miles of city start/stop driving, I can attest if you Climate control is set to MAX COOL, your truck will never "Auto Start/Stop".
Old Aug 29, 2017 | 07:33 PM
  #50
scottmeiners's Avatar
scottmeiners
I have my 17 set to max cool all the time and it shuts off all the time. However, I have not tried it with the blower on the highest setting to see if it shuts off. With the blower on 4 or 5, when the motor turns off, the blower slows way down.
Edit: I tested this morning, if I have the blower set on max the start/stop is disabled. So that is good to know.
Old Aug 29, 2017 | 09:23 PM
  #51
jimmy-six's Avatar
jimmy-six
I've ordered an 18 should be here the end of Sept. Start/stop is only a starter problem concern for me. I've had many apart but never on an engine that starts as quickly as these newer cars. Hopefully longevity won't be a major problem. I've sold my 13 ECO for a 5.0 and looking forward to a V8 again even tho the 3.5 towed as good as the diesel it replaced.
Old Aug 30, 2017 | 12:48 PM
  #52
GlueGuy's Avatar
GlueGuy
They've made changes that hold up the oil pressure much longer than "normal" such that those starts are not really "dry".
Old Aug 30, 2017 | 12:54 PM
  #53
CR172's Avatar
CR172
Please explain. Unless Ford switched to an electric oil pump, how can a non-running engine maintain oil pressure?
Old Aug 30, 2017 | 04:19 PM
  #54
GlueGuy's Avatar
GlueGuy
They might use an electric pump (IDK). However, I've read on Edmunds and elsewhere that it is more of a passive means to hold the oil in galleries and such. There might be a check valve (I'm speculating there), but the article I read was about having to wait ~~ 15 minutes for the oil to drain back.
Example: https://www.edmunds.com/ford/f-150/2...-you-wait.html
There are other things at play too, such as special anti-scuff coatings on the main bearings and so on.
Old Aug 30, 2017 | 04:37 PM
  #55
Big-Foot's Avatar
Big-Foot
.....and......
It's a long held fallacy that engine bearings need oil pressure to "float" them.
All it really takes is a very thin film of oil to keep the bearings from scuffing.
Oil pressure creates flow which then carries heat away from the bearings and journals.
I'm not at all concerned about the engine...
Old Aug 30, 2017 | 04:52 PM
  #56
PupnDuck's Avatar
PupnDuck
Nope, no pumps or solenoids. Remember, the start / stop system only begins to function once the engine has warmed up so there are no cold restarts. In addition, there is an electric pump in the transmission that provides the necessary pressure to keep the tranny in gear so that on restart the engine is limited to the rpm it would have in drive not idling in neutral. Between that and the fact that they are all hot starts there is no appreciable extra wear. It's also the reason that Ford uses a synthetic blend oil. In addition this ain't your grandpa's starter motor. It's designed for the job it does.
Old Aug 30, 2017 | 05:04 PM
  #57
thewheelman's Avatar
thewheelman
What's left? Off?
Old Aug 30, 2017 | 06:13 PM
  #58
PupnDuck's Avatar
PupnDuck
Originally Posted by thewheelman
What's left? Off?
Well, there is that. Also the system WILL shut down the engine when the cabin temperature is within a degree or two of the set-point in heat or A/C but NOT in defrost. Also, in Heat mode there is an electric pump which keeps hot water circulating through the heater core when the engine shuts down.
Old Aug 31, 2017 | 01:23 PM
  #59
storage_man
I have to re-track this statement " MAX COOL does NOT stop Auto Start/Stop. This morning, Max cool was on, I came to a stop light and the motor shut off. It was only 92 outside temp. As I waited for the light to change, the AC blower had stopped running, a very eerie silence and before the light changed, the engine cranked over 3-4 times, it started but was like shuttering, it then smooth out (Note I still had my foot on the brake). The light changed and off I went.
It look like the feature is activated based on temp, not what you have set. I was really disturbed by the shaky restart. Didn't sound good. ????
Old Aug 31, 2017 | 05:10 PM
  #60
PupnDuck's Avatar
PupnDuck
If the engine restarted while you still had your foot on the brake it was probably because the system detected that it was getting too warm in the cab. That's ONE of the reasons it won't shut down.
I wouldn't worry about the shudder. It's normal. Remember the engine is restarting against a trans that's still locked into first gear by the electric pump in the trans. Not like starting up in park or neutral.
