Steering Wheel position sensor
Old Aug 16, 2017 | 05:26 PM
Painted Horse's Avatar
Painted Horse
Anybody replaced their Steering Wheel position sensor. My dealer want $600 and it looks like the part is $40 How hard of job is it?
Old Aug 16, 2017 | 07:36 PM
Just Strokin's Avatar
Just Strokin
You have to pull the steering wheel and the clock spring. It is located under the clock spring.
Are you past the 3/36 warranty? If so, should be no charge to replace if bad.
Old Aug 16, 2017 | 08:05 PM
Painted Horse
Thank's Larry.
That doesn't look too tough
Mine has 77,000 miles. So I'm past the 36,000 bumper to bumper. So it's time for me to start doing some of the repairs. Can't afford $500-$600 for a $35 part repair
Old Aug 17, 2017 | 01:23 PM
troverman's Avatar
troverman
What failed? I wouldn't expect these parts to fail. Steering wheel position sensor would be used for the stability control system as well as the off-road display on the dash.
The critical part of this repair is making sure you keep your wheels straight and the clockspring "on center." I did one of these on another vehicle and didn't have things lined up. First hard left I took ripped the wiring out of the clockspring; the dash lit up like a Christmas tree.
Old Aug 17, 2017 | 10:19 PM
Painted Horse
My stability control light comes on. Every time I shut down, it seems to clear, But with in a mile down the road, The Stability Control icon illuminates. The error code say the Steering Wheel Position Sensor is bad.
Dealer was quoting about $150 in parts and the rest in labor. I'm finding the sensor at a SLC dealer for $39.28, and Autonation online for $25 plus shipping. I'm sure the steering wheel bolt is a few bucks that they say to discard the original and replace with a new one. So I'm not sure what other parts the dealer could possible be quoting to come up with a $150 parts quote.
I don't know what has caused it. They just replaced one caliper, two rotors, and the pads on the front and this light came on that afternoon after I picked up the truck. Maybe something shorted it out while they worked on the brakes or maybe it's just murphy's law and it had nothing to do with the brake job. Can't possibly point a finger and say they caused it. But the timing makes you wonder.
Old Aug 18, 2017 | 06:28 AM
troverman's Avatar
troverman
That's very odd. The brakes are connected to the stability control system, but only in the sense that the ABS sensors read wheel speed and the brakes themselves apply at the command of the ABS computer in order to correct a stability situation.
In my opinion, the steering wheel position sensor is one of those parts that should never fail and last the lifetime of the vehicle. Anything is possible, but that just seems unlucky.
Stability control may need to be calibrated after replacing the sensor.
Old Sep 12, 2017 | 11:47 AM
Painted Horse
Replaced the steering Wheel Position Sensor and still have the error light on the dash. So apparently the dealer's diagnostics were not accurate or complete. At least it wasn't very difficult or expensive to do.
But I hate throwing parts at a problem
Old Mar 14, 2021 | 10:50 PM
Maxime Sciamma's Avatar
Maxime Sciamma
Did you manage to find the problem and cause? I have the same issue with my truck and im abiut to start and find the problem.. mine came up right when i statted the truck 2 days after parking it after a 3h drive in a snow storm.. advancetrac repair popped up and the signals arent shutting off on there own anymore..
Old Mar 15, 2021 | 04:51 AM
troverman's Avatar
troverman
Maybe Painted Horse can answer? Although I believe he has a new truck...
Old Apr 22, 2023 | 12:28 PM
Jenksie13's Avatar
Jenksie13
Anyone have an update
I replaced my clockspring and the piece behind it would not snap in place like the original did, like it didn't fit as in they maybe upgraded the clockspring, but I lined everything up. My Service Advanctrac light started coming on right before the swap and my steering radio controls and airbag light was on. The clockspring swap fixed the steering controls and airbag lights now off but the Advanctrac light still comes on. PITA so any help is appreciated.
Thanks
Old Apr 23, 2023 | 07:54 AM
DaveyMac's Avatar
DaveyMac
After replacement you may need to Program new part to BCM with a Bi-Directional Scan tool.
Old Apr 23, 2023 | 10:57 AM
acdii's Avatar
acdii
Just keep in mind that after warranty, you really don't need the dealer to do the repairs. Any independent shop can do anything the dealer can with the exception of IDS updates.
RojoStar
Aerostar
Mar 9, 2016 09:06 AM
FORDF100SB
Aug 13, 2015 03:27 PM
garagegods
13
Jul 21, 2015 08:58 AM
robjs111
Ford Truck Parts for Sale
May 23, 2013 12:02 AM
72Truckin
44
Feb 1, 2013 09:24 PM
