*** The Official Superduty Morning Coffee Thread ***
#7787
That ‘haze’ on the mountains is ‘air you can wear’. Unusually hot and muggy for here. 82* and 83% Rh when I took this.
Thank God for the little t-storm that brought temp down to 74* and provided some clouds. It’s pretty damn nice now!!
The tallest point in GA is in the background a few peaks to the right of my CB antenna. Brasstown Bald is almost 4800ft above sea level.
#7790
#7791
#7793
#7794
The temperatures you all reporting is cooler then here, been 80’s and into mid 90’s . humidity comes and goes.
#7797
At the caliper's nip.
Gravity bleed so you can suck a beer down while you do each caliper...or use a pressure bleeder if on hand (just verify reservoir level often). Motive makes awesome units for pressure bleeding. Consider fresh hoses if the truck is getting up there in age. I like to replace each decade.
PS are you rocking Crocs?
#7798
#7799
WHAT THE HECK???? Wonder if that is an author with writers block just trying to break it or what?? That was funny for sure.
