Problem with tailgate
Old Aug 15, 2017 | 05:03 PM
tony montana 42's Avatar
tony montana 42
Have a 17 king ranch, only had it for 2 weeks. Has the electronic push button on the gate and keyfob to open the gate. How ever it will not open. Is there a setting on the truck that has to be turned on or is there a electrical Problem
Old Aug 15, 2017 | 05:13 PM
BowtieConvert's Avatar
BowtieConvert
When will it not open? If you have the key fob on you it should open when you mash the button. What about the release button inside the truck or the button on the key fob? Do any of those work?
Old Aug 15, 2017 | 05:42 PM
wb6anp's Avatar
wb6anp
Not sure it applies to the fob, but for the dash button, and the taligate button to work on mine, the truck needs to be unlocked first. It depends on your unlock settings you may need to hit the unlock on the fob twice to unlock all doors. Since I have a shell I never open my tailgate with the fob.
Old Aug 15, 2017 | 06:22 PM
tony montana 42
No I can't get it to open at all. I also hit the button inside of the truck, did nothing, I have hit the button on the key fob twice like it says as well
Old Aug 15, 2017 | 10:39 PM
pickerdd's Avatar
pickerdd
I had the same problem. My dealer had to replace the tailgate actuator. That solved the problem.
Old Aug 15, 2017 | 11:17 PM
wb6anp's Avatar
wb6anp
Did you have the trailer 12 pin plug installed for the trailer tpms and camera? If so the dealer may have connected it to the wrong plug under the bed. another member had the same issue and found they had used the tailgate plug not the plug for the tpms/camera.
shipper
May 27, 2018 07:47 AM
Slayer5000
2015 - 2020 F150
Jul 29, 2017 10:37 PM
Chris Karsseboom
Jun 13, 2017 11:07 PM
troverman
Jun 1, 2017 08:19 AM
EightySecond
Oct 17, 2016 06:43 PM
