No start, help needed!
Old Sep 6, 2017 | 08:39 PM
DieselDenny's Avatar
DieselDenny
If your batt lite is on, you still need to check the alt output, Easy to do. Just make sure you have proper voltage to any pos connection. I'm suspecting a ground issue.
Fly thru every ground and clean them up. (easily done) Usually folks are worried about everything red/nah.
Check em.
Denny
Old Sep 6, 2017 | 08:43 PM
DieselDenny
Kinda look at it this way, if the computers head is cloudy because it doesn't have complete power (hangover perhaps), ain't happnin.
Old Sep 7, 2017 | 07:45 AM
Tugly's Avatar
Tugly
Really, really, really check all your grounds - and don't forget to check grounds in reference to the battery post, not just the cable.
Old Sep 9, 2017 | 09:23 AM
ExPACamper's Avatar
ExPACamper
Check your alternator for AC ripple. If a diode goes bad, it doesn't rectify the AC to DC properly and some of it leaks through the system as noise.
If so, it can interfere with anything electronic- PCM, Programmers, etc.
Note: NEVER disconnect the alternator while running or cranking. I'm told it will fry it :eek
Glad you got it started!
Another thing to check is the EOT after sitting overnight and before starting (should match ambient temp). I've recently read that if the EOT isn't reading correctly, it can lead to a no-start as the truck thinks the engine is already warmed-up.
Let us know how you make out
ckal704
Sep 6, 2017 09:18 AM
1996stroker
29
Jul 8, 2012 06:30 PM
dvfd12
Feb 5, 2007 08:07 PM
Mindstream
34
Jan 26, 2007 07:32 PM
TNT in Round Rock
Dec 7, 2006 12:06 PM
