Sponsored by: Real Truck
Steering Damper
Old Aug 12, 2017 | 08:31 AM
Greynomad's Avatar
Greynomad
Steering Damper
Motorcraft steering damper for 4wd is 36 and change
Bilstein Steering damper for 4wd is 84 and change.....
What is the difference btw the two and is Bilstein a better buy?
Old Aug 12, 2017 | 10:09 AM
Bently_Coop's Avatar
Bently_Coop
My truck wasn't equipped with a damper, I did purchase the brackets through Ford and the Bilstein damper, definitely cleared some feedback in the steering wheel, looks shiny and matches the other Bilstien shocks I have.
Old Aug 12, 2017 | 01:47 PM
speakerfritz's Avatar
speakerfritz
They all are about the same because of the slop in the links on where they connect.
Wow factor doesn't happen until you go to dual stabilizers that bolt directly to the drag bar ends with no links in between.
Old Aug 13, 2017 | 02:26 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I had the OEM stabilizer for 45k miles, dual BDS for 30k, none for 20k, now a Bilstein for the last 20k. Couldn't really tell a difference in any of the above except the dual turned harder.
Jameson JC
Jun 20, 2013 11:20 PM
nghtrgr
Jun 2, 2010 12:34 AM
PowerstrokeJunkie
Jun 14, 2007 11:31 AM
truckman
Mar 16, 2004 05:23 PM
