Tailgate swap
Old Aug 11, 2017 | 03:43 PM
Warhawk77's Avatar
Warhawk77
Tailgate swap
Anyone got info on swapping tailgates on these trucks?
Wondering if the 80s or 90s gates will fit at all. I'm guessing they might not have the right lines but mainly wanting to know it they will fit in the hole.
Thanks
Old Aug 11, 2017 | 07:00 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
For sure the body lines will be way off.
73-79 bolts on, both sides...80's and up I think has the slip on/off set up on the R/H mount tab. I think...
Also some time they went from hinged straps to cables.
Old Aug 11, 2017 | 08:55 PM
paredneck33's Avatar
paredneck33
That's correct Rich. That was 83 or 84 that they switched to the cable strap from the metal hinges. Also they had to change the latch and strikers to go along with the cable straps. And all of those parts would need to be swapped out and retro fitted to the truck bed for those tailgates to work on a dent.
Old Aug 11, 2017 | 09:20 PM
77&79F250's Avatar
77&79F250
Thanks for the info on that, but IMO an 80's and up tailgate on a 79 (due to the body line misalignment), will look like a dunce hat on a donkey. lol
Here is an earlier 6 something-ish ? to 72? bumpside (?) tailgate on a 79...just not quite right. The handle is hinged from one end...I doubt a 80's and up would line up any better.
But best of luck there Warhawk.
Old Aug 11, 2017 | 09:43 PM
paredneck33
I completely agree with Rich on the look of the tailgates. And yeah the 67-72 bumpside tailgates don't look good either.
Old Aug 12, 2017 | 10:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
80/82 Styleside tailgate supports are made as part of the latches.
1983/96 Stylesides use specific right & left tailgate support cables.
C4TZ-9944400-A .. Tailgate Support (aka scissor) / Right/Left is the same.
1964/66 F100/250 2WD; 1966 F100 4WD; 1967/79 F100/350.
1973/79 F100/350 Styleside tailgates (except the supports) use completely different mounting parts than these 1964/66's & 1967/72.
Not only does the 1973/79 Styleside tailgate look completely different, but the tailgate handle is also different than these 1964/66's and 1967/72.
Old Aug 14, 2017 | 07:18 AM
Warhawk77's Avatar
Warhawk77
Thanks for the info. I would like to get a Gen 6 tail gate for sure but those are hard to find in good shape. Don't want to order a new one just yet but would be nice to have something to so I can "finish" the bed section.
Old Aug 27, 2017 | 12:12 PM
bulldogcountry1's Avatar
bulldogcountry1
I've been mulling over using an 83/96 tailgate to upgrade mine. I was wondering how hard it would be to use the 83/96 tailgate inside skin and ends to retain all the hardware mounting points and then skin the outside with the dent metal.
I was hoping to find someone who had done something similar, but no luck. It's probably just too much trouble. Maybe just servicing the existing hardware would be best. I'd like to at least swap the metal supports for cables.
Old Aug 27, 2017 | 12:17 PM
NumberDummy
1980/82 Styleside tailgate has the supports made as part of the R & L latches.
1983/86 Styleside tailgate uses R & L cables, the latches are separate.
Old Aug 27, 2017 | 08:10 PM
bulldogcountry1
What year did Ford switch from the wedge bolt latches to the bear jaw-style latches?
Old Apr 9, 2026 | 09:37 PM
Abraham Solis's Avatar
Abraham Solis
Trailering
Thanks
My 79 Ford truck does have a 67-72 tailgate, it fits but the lines do not match
My 79 Ford truck does have a 67-72 tailgate and it fits, but the lines do not match
351Cleveland C4
Aug 27, 2016 12:04 PM
Ripcity
Sep 19, 2013 08:52 AM
Canus
Apr 29, 2012 10:49 AM
old76er
13
Dec 7, 2009 01:58 AM
scottie2hottie
Nov 21, 2006 04:28 PM
