Dash/tail light issue after new ignition
Old Aug 11, 2017 | 01:51 PM
55fordv8's Avatar
55fordv8
Hi
I just put a new ignition in my fathers 1955 F100 which is now 12v negative ground.
The switch was a bit different as there was the 4th un-needed post in the middle had we wanted to eliminate the old starter button (which we don't).
I did the wires one post at a time doing the following:
wires on COIL I put on IGN
wires on AM I put on BAT
wires on GA I put on ACC
My issue is now the dash lights and the tail lights stay on even with the key in the off position. I have to assume I have something extra attached to the BAT post that in the past didn't matter but does with this new switch. Everything else works great.
Any ideas?? Is there a separate wire for just the dash and tail lights. If so, what post should it go on?
Thanks
Deb
Old Aug 12, 2017 | 11:39 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
I'm old so forgive me but all your lights run off of your LIGHT SWITCH. I'm having trouble figuring out why changing your ignition switch would cause light issues.
Here's a diagram to try to help.
https://www.google.com/search?q=55+f...01VyySsESNSCM:
Old Aug 12, 2017 | 02:37 PM
55fordv8's Avatar
55fordv8
Hi
Thanks for the diagram. It helped. So it was something I did. I accidentally pulled a wire off the dash cluster and put it back in the wrong spot making the lights stay on. Once the wire was back in its correct spot all was well.
Thanks again for the reply.
Old Aug 12, 2017 | 04:18 PM
bjmayberry2
Originally Posted by 55fordv8
Hi
Great news. Now get out there and enjoy the ride.
nightowl263
Jan 2, 2015 09:41 PM
luvrocks
Feb 2, 2009 05:10 PM
johninraleigh
Dec 22, 2007 11:05 AM
jnjdickson
Electrical Systems/Wiring
Dec 13, 2003 06:14 PM
jrhix
Aug 6, 2003 04:35 PM
