No Dash Lights
Old Jan 30, 2009 | 03:04 PM
luvrocks's Avatar
luvrocks
No Dash Lights
hi guy's need some help with this one 1989 E-250 I have no dash lights all the other lights work so I start at the light switch find the LB/R wire is the dash lights wire start tracing it till it runs into the big wire bundle have power till there can't find the book on this thing so what I need is a wire diagram for the dash lights to follow it to were they go to see if I'm missing something like a relay and were it might be at TIA. forgot to say checked the fuses all good.
Old Jan 30, 2009 | 04:40 PM
rclarke's Avatar
rclarke
Simple solution first. Try turning the light switch **** with the lights on. Sometimes the **** gets turned to very dim or off.
Old Jan 30, 2009 | 05:13 PM
luvrocks's Avatar
luvrocks
One of the first things tried,even took some 2000 sandpaper and made sure the contacts were clean with no luck.
Old Jan 30, 2009 | 05:15 PM
luvrocks's Avatar
luvrocks
used a test light on the LB/R wire and turned the **** and the light slowly dimmed and came back up to full brightness
Old Feb 2, 2009 | 05:10 PM
tnau664's Avatar
tnau664
Hey guy, this happened to me last fall. I lost the tail lights at the same time.
Try working the light switch in and out slowly to find the sweet spot. I was able to get my dash (and tail) lights on till I could get a replacement switch. New switch and all is right with the world. At least the dash light world.
These are really easy switches to replace.
T
nightowl263
Jan 2, 2015 09:41 PM
pin8246
Jun 3, 2013 02:01 AM
Bob Landry
Mar 22, 2013 04:05 PM
mbettez79
Sep 12, 2008 12:15 PM
jwoody47
Oct 18, 2002 02:12 PM
