Wiper motor electrical diagram help, 05 6.0 powerstroke.
So I'm finishing the final touches on my 6.0 powerstroke f100 project, and I'm currently working on installing the wiper motor, as you all know the super duties have the wiper motor outside the cab, but since this is a project using a f100 body, I have to install the wiper motor inside the cab, where the old motor used to go, I have it all figured out, but I need to power the wiper motor before i put the dash back on to make sure that things will work with the wipers as it should, I search around to see if I could find wire schematics but came out empty handed, I'm hoping that one of you fine gents have this info somewhere, thank you in advance.
Old wiper motor mount, where new motor will go.
I had to take apart the wiper motor connector, in order to feed it thru the fire wall.
Markhlewis
10-07-2018 02:08 PM
RonKrem
03-11-2016 10:56 PM
Barney58F100
01-07-2016 06:56 PM
