Sponsored by: Real Truck
Adding Backup Camera to 2014 XLT
Old Aug 11, 2017 | 01:54 PM
cashcrazy's Avatar
cashcrazy
I found a good deal on a 2014 XLT and it does not have a back-up camera. It has the basic SYNC package and probably the lowest AM/FM/CD receiver available in the XLT, so no screen at all. I've read tons of threads about adding a camera and have narrowed it down to adding a receiver with a screen or the rearview mirror camera.
Does anyone know if adding the aftermarket receiver with a screen capable of camera display will interfere with the SYNC function. I do use the voice commands often when driving. This is my concern with changing the radio. The rearview camera would serve the purpose, but the only kit I have found is about $500. I think changing the receiver would end up costing about the same and has the ability for a front mirror camera also.
I assume that adding a factory 4.4" display is not compatible with the wiring harness in my truck so I have ruled that out. I appreciate any info from those who have added a camera. Thanks!
Old Aug 11, 2017 | 04:02 PM
Crispy71's Avatar
Crispy71
I added a factory Nav touch screen stereo and a back up camera to my 2012. It was a bit more than $500, however it was practically all plug and play. I know there are aftermarket head units and interfaces that will work with Sync, you have to do a little more wire surgery though.
Old Aug 11, 2017 | 04:06 PM
cashcrazy's Avatar
cashcrazy
I wouldn't mind adding a factory setup like that. I believe the temperature controls are also different on those models. Did you buy this as a package or piece it together?
Old Aug 11, 2017 | 04:16 PM
Crispy71's Avatar
Crispy71
The Nav and backup camera from 4D tech was a kit. I'm happy with the work 4D tech did and they also will answer you questions. I added the Woodgrain and the temp controls separately. I think I put all the info in my write up. The only thing I haven't done is get the second door and actuator for making it a true dual zone AC system.
Old Aug 11, 2017 | 04:28 PM
cashcrazy's Avatar
cashcrazy
I just checked out 4D tech and the nav retrofit is $1549, but their kit looks complete. I appreciate the tip!
Old Aug 11, 2017 | 04:31 PM
Crispy71's Avatar
Crispy71
It is complete and the instruction are top notch. As I recall I only had to disassemble one wiring connector to add the wire for sync connectivity, and that only took about five minutes. Altogether I took about 90 minutes to install everything.
Old Aug 11, 2017 | 04:38 PM
Crispy71's Avatar
Crispy71
By the way, since I forgot...... You're Welcome!
Old Aug 11, 2017 | 05:23 PM
mzwizanski's Avatar
mzwizanski
I used this kit and it works great! It has a factory camera in the tailgate logo. I paid $350, but I see its on sale now.
https://tailgatecamera.com/collectio...guidance-lines
BIGRED 011
Apr 14, 2016 06:15 AM
mrjc
6.7L Power Stroke Diesel
60
Nov 22, 2013 04:28 PM
tgreening
Sep 14, 2010 04:59 PM
tgreening
Sep 12, 2010 10:07 PM
rynopolis
2004 - 2008 F150
Jan 6, 2007 06:59 AM
