05 dash panel cracking
Old Aug 11, 2017 | 08:51 AM
breezy5000's Avatar
breezy5000
Was wondering if anyone else's black dash panel has cracked or broken. My EX is from Oklahoma but had been garaged most of its life paint is good, the plastic outside on mirrors and cowl are still black but the dash panel is brittle. I installed a new radio and broke it just above the cluster taking it off glued that back together got the radio installed and all was good for about 2 months then it started cracking around the radio. Now the radio just slides in and out. Anyway I'm in need of a new dash panel not sure if I should go with an 05 or paint an older one to match.
Old Aug 11, 2017 | 10:09 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I can get you brown or grey from 00-01 trucks. Shipping won't be cheap on those things. They will come from the Gold Mine near me. I doubt you will find one new, but I could be wrong.
Old Aug 12, 2017 | 09:01 PM
breezy5000's Avatar
breezy5000
Thanks Nicmike I think I can find one local was just trying to figure out if the black panels prone to this or not.
Old Aug 12, 2017 | 11:14 PM
ComanderDuke's Avatar
ComanderDuke
I don't if they are or not mine was broken by previous owner around the radio and climate control area, but the top did develope a crack and then basically it fell apart when I went to replace it
Old Aug 13, 2017 | 06:29 AM
Rollinstone71's Avatar
Rollinstone71
I had the same issue on my 05 truck when I bought it. Indoor kept truck with 83K, the dash broke up in my hands after i tried reinstalling. I bought an 05 tan and had it painted. It's hard to find a black 05 excursion one anyways
Old Aug 13, 2017 | 08:52 AM
Jeremy05's Avatar
Jeremy05
Yep the 05 black dash bezel is hard to find. The excursion dashs are different than the truck ones in the design. The truck ones will snap in place of course, they just look different. The only truck dash bezel that matches is the in the king ranch dash. It would have to be painted as well, as they only came in tan.
Old Aug 13, 2017 | 09:15 AM
mecdac's Avatar
mecdac
How so? Tell me more.
Old Aug 13, 2017 | 10:49 AM
Jeremy05's Avatar
Jeremy05
Not sure if your serious, but here goes.
I'm including 3 pictures. One excursion, one regular pickup, and one king ranch pickup. The most noticable difference is the look in the area above the instrument cluster.
My example pictures dont have the same options, the pickup dash in the picture is missing the esof switch etc.
Regular pickup bezel
Excursion
King Ranch
Old Aug 13, 2017 | 11:15 AM
mecdac's Avatar
mecdac
Yes, I was serious. Thanks for the pictures.
The only difference I perceive is the inlay/notch line surrounding the instrument cluster. Probably a Model Year difference. Didn't the '05 have semi-circular air vents?
Various options:
Only the Excursion has rear window defrost
ESOF switch.
Passenger Airbag On/Off
Parking Sensor
Foot Pedal Adjustment
Old Aug 13, 2017 | 12:12 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
There is another difference. It is the shape of the headlight switch. Trucks were all square (except that KR dash), and the excursion is oval. If you switch to a truck bezel, you will need to swap the switches as well.
My tan 01 panel has been parked in the driveway for the 5+ years I have owned it. In the hot Texas heat/sun. No cracking here, and I have had it in/out several times working on wiring, steering column, vents, etc. Maybe the black tint in the plastic is responsible for the brittle nature of the plastic? I did have a 02 Dodge pickup before the X, and it fell apart if you just looked at it. Common problem on the Dodges.
Old Aug 13, 2017 | 12:54 PM
mecdac's Avatar
mecdac
Nice catch, I missed that.
Old Aug 14, 2017 | 05:15 AM
Rollinstone71
Just be sure to salvage all your black dash panel switches and ac vents and all you'll need to do is have the shell painted the reinstall everything. I got a tan excursion painted one so everything fit right and it still had the "excursion" name plate
Old Aug 22, 2017 | 10:28 PM
breezy5000's Avatar
breezy5000
How much you think it would be shipped to 64155?
Old Aug 22, 2017 | 11:16 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I can find out for you.
He has a grey 2000 Excursion panel and a brown 2000 Excursion panel. I don't know the differences between the 05 and 00. Maybe post up a pic of yours?
Old Aug 23, 2017 | 12:26 PM
Excurvelle's Avatar
Excurvelle
Is your dash panel cracked or is the black finish flaking off?
