7.3 Occassional Misfire (2 cylinders and other times 4)
I've noticed that in the 96 PSD I recently purchased that once in a while, I get 2 cylinders that miss. Other times it sounds like 4 cylinders are missing. It's got 330k on the clock. Exhaust is clear and it fires right up in 60 degree weather even with glow plug relay unplugged for testing.
What should I be looking for? I swapped in a spare IDM from another 7.3 I had previously and that didn't change anything.
Check the valve cover pins, and harness for burned pins. Also check if the harness pigtails have ever been changed out, and if they have , that the wires are soldered together. Butt connectors are not a good option, as I tried them a few years ago, and got a misfire after a year or so use. after soldering the wires I had no more problems.
70spoiler
01-21-2011 09:58 AM
Nickiboy
08-16-2004 08:29 PM
