transmission not shift
Old Aug 10, 2017 | 08:34 PM
Mead ex's Avatar
Mead ex
2000 v10 auto 4x4 Transmission started today not shifting gears Pull shifter in Drive and in will start out in first gear and shift to second at about 4000 rpm and then stay in second Any help Thanks in advanced ps about 225000 miles
Old Aug 10, 2017 | 09:12 PM
metru's Avatar
metru
it starts in gear? like if you turn key the truck trys to move? or just the indicator on the dash shows that its in gear when you start? if only the indicator shows then could be worn out linkage or corroded wires
Old Aug 10, 2017 | 09:46 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first step is to get the codes read. The places that read codes free cannot read these codes. You need either a good independent shop or a Ford dealer.
Koleba11
Dec 15, 2018 01:02 PM
Jacobsele
Apr 12, 2017 08:39 PM
davidhaney
Oct 30, 2016 10:00 AM
kameronth
May 27, 2014 09:51 AM
Aune163rd
Modular V10 (6.8l)
13
Jan 27, 2014 11:20 AM
