Fusible link
Old Aug 10, 2017 | 07:45 AM
Rudiak's Avatar
Rudiak
Fusible link
92 F150 302. Does anyone know if there is a fusible link in the wire off the s - post of the start solenoid on pass side fender and if so the specs on it?
Old Aug 10, 2017 | 08:15 AM
subford's Avatar
subford
No there is no fusible link on the S-post of the starter relay on the passenger fender.
Old Aug 10, 2017 | 08:28 AM
quaddriver's Avatar
quaddriver
are you looking for a specific link for a specific reason?
or are you trying to start it and the solenoid aint firing? (diff fixes for both paths so please tell us why you ask)
Old Aug 10, 2017 | 09:16 AM
Rudiak's Avatar
Rudiak
The wire off the s post where it goes into the bundle is broken or corroded because when it won't start I jiggle it and it starts. It looked like it had a fat section going into the bundle but I will have to start removing all the tape. I'm going to replace that section of wire once I determine the wire size. Thanks!
Old Aug 10, 2017 | 09:27 AM
quaddriver's Avatar
quaddriver
its a small load wire, 14-16 should be fine without looking at the SCM, it is only energized when KOES and Neutral/Park or clutch in is met. And its the greatest theft deterrent for OBS trucks around as it corrodes and they just wont crank
Old Aug 10, 2017 | 09:29 AM
quaddriver's Avatar
quaddriver
btw - if you whack it with a good does of deoxit or contact cleaner and chase the S post with a nut, then seal with vasoline it should last a bit
Jimmyl21
Aug 1, 2017 02:51 PM
Charlest1
Jun 29, 2017 10:33 PM
77150351M
Oct 7, 2015 07:25 PM
F125Lariat
Dec 16, 2014 06:38 PM
Trampus
1978 - 1996 Big Bronco
Oct 8, 2003 05:58 AM
