Tire pressure question
Old Oct 21, 2021 | 02:40 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I disabled my TPMS, and run 50-60 front and 40-50 rear when empty.
Old Oct 21, 2021 | 06:38 PM
Norris McCarty's Avatar
Norris McCarty
When you disabled the TPMS via forscan do you get any kind of warning at startups?
I’m getting ready to do forscan and would rather not use even minimum values because I air down to 28psi every once in a while off-road.
Old Oct 21, 2021 | 06:43 PM
Chris 86's Avatar
Chris 86
I run 50psi front and back. I have confirmed with a cat scale that even with a loaded bed and travel trailer attached, 50 PSI keeps me within weight ratings. If I am going on a long distance trip, I will put the rears to 60 or 65, mostly for a little extra MPG .
Old Oct 21, 2021 | 07:51 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
None at all. Truck functions normally
Old Oct 21, 2021 | 08:25 PM
Grey SD's Avatar
Grey SD
Here is what Michelin recommends for the 20 inch tire
CNC
May 2, 2010 10:44 AM
ssharber
Oct 1, 2008 12:42 PM
mjunk1
1997 - 2003 F150
15
May 19, 2008 09:08 PM
Peter Nikols
1997 - 2003 F150
May 21, 2004 02:05 PM
LSUFX4
2004 - 2008 F150
Mar 12, 2004 10:16 AM
