1988 460 timing
Old Aug 12, 2017 | 08:31 PM
fordtrucks99's Avatar
fordtrucks99
Sorry. Yes I have an 11 code. No memory codes.
Old Aug 12, 2017 | 10:45 PM
vjsimone's Avatar
vjsimone
Both the KOEO & KOER ?
Old Aug 12, 2017 | 11:29 PM
fordtrucks99
KOEO I'm only getting code 11. KOER only code 21 for the ect out of range.
But I may have not had the coolant temp hot enough if thats a possibility. So I tested the harness which has 5v and the sig return has continuity to ground. Put in a good sensor I had just to be sure. Have not re-run the koer test again yet.
Old Aug 12, 2017 | 11:35 PM
fordtrucks99
Tomorrow morning I'll perform the KOEO and KOER tests again and psot the results to make everything clear.
Old Aug 12, 2017 | 11:43 PM
vjsimone's Avatar
vjsimone
Engines are easier to diagnose over the internet when all the codes are listed, and in order of test.
KOEO - (O) Self-Test Codes =
KOEO - (C) Continuous Codes =
KOER - (R) Self-Test Codes =
Old Aug 12, 2017 | 11:51 PM
vjsimone's Avatar
vjsimone
Sometimes a loose or corroded connector will cause that.
Old Aug 13, 2017 | 02:09 PM
fordtrucks99
KOEO self test codes: 11
KOEO continuous codes: 33, 51, 96
(First) KOER codes: 33, 72, 73
(Second) KOER codes: 33, 42
DId the KOER self test again because I messed up the goose.
Old Aug 13, 2017 | 02:10 PM
fordtrucks99
For the 33 I pulled off the EGR and applied vacuum and the valve is stuck closed. No exhaust entering the intake.
The 96 I think is from when I was doing the compression test with the key on and the fuel pump relay unplugged.
Old Aug 13, 2017 | 10:55 PM
fordtrucks99
I almost had to do a third KOER self test because the truck was about to stall out a few times.
Old Aug 14, 2017 | 07:33 PM
vjsimone's Avatar
vjsimone
Have you replaced your Cap & Rotor ?
Old Sep 4, 2017 | 12:00 PM
fordtrucks99
The owner needed the truck back. I don't know if I found the exact cause but I did find that the cat was clogged. Quickly removed the insides and reinstalled. Truck didn't stall anymore but still ran pretty bad. Could the clogged exhaust cause buildup on other components causing the rough running? Anyway the owner has the truck and is using it now. I figured some seafoam to clear it out a little. Thank you to everyone who helped me.
Streetgliderr
Jun 3, 2014 09:21 AM
Boondocker
Apr 6, 2008 10:35 AM
christcorp
May 17, 2007 03:55 PM
AirSmitty
Jan 28, 2006 03:52 PM
GSchretter
Oct 6, 2004 02:06 PM
