1988 460 timing
Old Aug 9, 2017 | 10:15 AM
fordtrucks99's Avatar
fordtrucks99
1988 460 timing
So I set the timing on the engine to 10*BTDC. Shut the truck off to tighten the distributor hold down bolt. Try to restart it and it wont start. If I retard the timing cloe to TDC 0* it will start and idle. What should I look for?
Old Aug 9, 2017 | 10:19 AM
quaddriver's Avatar
quaddriver
did you unplug SPOUT before doing the set?
Old Aug 9, 2017 | 10:49 AM
fordtrucks99
Yes forgot to mention that.
Old Aug 9, 2017 | 11:42 AM
quaddriver's Avatar
quaddriver
im curious if the tab is not right or the balancer ring has slipped. might have to determine tdc the old fashioned way and see where things are pointing AND make sure the right wire on the cap is pointed to by the rotor...
Old Aug 9, 2017 | 12:51 PM
fordtrucks99
The pointer is in the right position and isn't loose. The balancer looks like it hasn't slipped, rubber looks undamaged. TDC is correct on the balancer according to the pistons position. And the rotor is pointing at the number 1 distributor cap contact.
Old Aug 9, 2017 | 01:25 PM
88XLTLariat's Avatar
88XLTLariat
New distributor? Have you checked for a PIP signal?
Old Aug 9, 2017 | 02:50 PM
fordtrucks99
No not a new distributor. Haven't checked for PIP signal
Old Aug 10, 2017 | 04:25 PM
fordtrucks99
If I'm getting spark at all of the plugs using a spark tester wouldn't that mean the PIP signal is good
Old Aug 12, 2017 | 01:02 AM
fordtrucks99
I'm lost on this truck. I have correct fuel pressure, injectors all measure 11 ohms, 12v to all injectors, ground pulse to all injectors, spark at all plugs, clean airway, no codes, no vacuum leaks visually, compression all within 150 psi. I don't know where to go now, I need some suggestions.
Old Aug 12, 2017 | 01:34 AM
88n94's Avatar
88n94
Where are you at now? In your original post under #1 you said if you set the timing at TDC the engine would start and idle. Do you have a complete no start now or what?
Old Aug 12, 2017 | 08:57 AM
fordtrucks99
Well the original issue was it was idling rough and hesitation when accelerating which it still has. So I wanted to check ignition timing which was set at around 0*. At 0* the truck would start and idle somewhat. When I adjusted it to the correct 12* it wouldn't start at all. So now its still retarded to about 0* so I can at least start it and move it.
Old Aug 12, 2017 | 09:01 AM
fordtrucks99
The idle is up and down in rpms and sometimes gets so low that it stalls out.
Old Aug 12, 2017 | 09:04 AM
quaddriver's Avatar
quaddriver
idle - isc problem. are you sure you went 10 before and not after?
Old Aug 12, 2017 | 12:18 PM
fordtrucks99
Yes 10* before. I had the iac valve off and it opens and closes using jumper wires. Backprobed it and it has 12v and a ground signal.
Old Aug 12, 2017 | 06:49 PM
vjsimone's Avatar
vjsimone
Originally Posted by fordtrucks99
no codes
"no codes"
What about "Pass" codes, or "Continuous Memory" Codes?
