I have 400 MF power steering box, I would like to use the original column. Does anyone make a steering wheel (15") for the OE column?? I am pretty sure I have not seen a smaller original style wheel .if anyone has used this set up , what else should I look for? Has anyone used the CPP column from MF? Just looking if I decide to change it. Thanks Dean
Pretty sure Grant makes an adapter for the stock column and then you can use one of their after market steering wheels.
Don't forget you'll need to address your horn (won't run through the shaft anymore) and a bearing in the bottom of the original steering column to keep it straight.
thanks rusted56 & bjmayberry ,I will do more research
