My turn: questions about F100 Crown Vic swap
Ok, so I'm sold by the math of the CV swap - lowers, adds sway bar, better geometry, modern steering, and brake improvement for around $400 (in my case.)
But I'm loving my 15" hubcaps.
Has anyone sucessfully mounted a 15" wheel on a CV swap? different calipers/rotors? shaving parts?
I'm looking at an '08 CVPI71 donor, if that makes a difference (I don't think it does, save springs?)
Some guys do use the CV rear. But it is real wide and I personally think it looks goofy, particularly under a bumpside.
As for 15" wheels, I think it really depends upon the design of the wheel. Steel wheels are probably a no go, due to their shape on the inside of the rim. Some aluminum wheels will fit. I put a 15x4 on the front of Nanner just to check fitment.
https://www.ford-trucks.com/forums/1...after-all.html
The bumpside CV install dimensions are the same as dents up front.
There is a CV swap group on FB with several vendors that make parts to make the CV install as painless as possible.
It will cost you more than $400 when it's all said and done, but wow, I really like how mine drives and rides now.
I don't know if it is or not. I know some of the threads I have seen I don't remember the measurement of front/rear tracks.
I know 1 thread that used the CV rear he was on a flare side and he made the rear fenders wider. This can be done easy on a flare side with bolt on fenders.
I have been following all the CV swaps as I would love to do it to my 81 F100 flare side someday.
Dave ----
parts car
well, my new suspension and brakes arrived (and by arrived, I mean that I got up at 4am to drive a 6.5hr roundtrip to get this thing)
also, found a photo (sort of) of the 16" V6 Mustang 'Halibrand-inspired" wheel on an F100. THis will be my fallback plan if I can't McGuyver up a way of making the 15" wheels work. (Has anyone looked at custom hub modifications to the CV stuff?)
