196? F600
Old Aug 7, 2017 | 10:04 AM
Dirty Offio's Avatar
Dirty Offio
196? F600
Hey guys,
I am looking at buying an f600, vin F60CRF11670. Can anyone break down the engine/etc fdom the vin? Guy says it is a 66, but the body is a 67-72. He says the engine is a 292, but i can tell it is an FE block...so I thought i would try to get some better info.
Thanks!
Offio
Old Aug 7, 2017 | 11:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Dirty Offio
I am looking at buying an F600, VIN: F60CRF11670
Guy says it is a 66, but the body is a 67-72. He says the engine is a 292, but I can tell it is an FE block.
F60 = F600 (gas).
C = 330 2V Medium Duty FT engine.
R = San Jose CA Assembly Plant.
F11670 = 1969.
FT engines look similar to FE engines, but FE engines were not installed in anything larger than an F350.
1964 was the last year that 292's were installed in trucks.
Old Aug 7, 2017 | 07:04 PM
Dirty Offio
[QUOTE
FT engines look similar to FE engines, but FE engines were not installed in anything larger than an F350.[/QUOTE]
Bill,
I actually knew that...and if I had engaged my brain, I would have looked like less of a doofus! lol If I remember right, the FT's have 4 ring pistons, steel cranks, and the balance was different. (I forget which was internal...)
Thank you for the number crunching!
I had tentatively ID'ed the truck as 1968 to 1972, strictly on the heater controls.
Dad had a 292 in a 1955 F600 when I was a kid...and those Y blocks are kind of distinctive!
Again, Thanks for the # work.
Cheers!
Offio
Old Aug 7, 2017 | 07:12 PM
JEFFFAFA's Avatar
JEFFFAFA
330 M/D had an Autolite 2V carb and a Dizzy like an FE. 330 H/D,361,391 had Holley carbs and a huge Dizzy. Both were part of the governor system.
Old Aug 7, 2017 | 09:21 PM
RichS2659's Avatar
RichS2659
I remember when my dad worked for a feedlot back in the '80's. He was constantly buying Holley 2V's for their F-600 feed trucks. I told him that I wanted a couple to rebuild to put on my 72 F-100 302. He gave me a couple which turned out to have the venturi's burned and melted in them. That was the state of all of them he replaced with new carbs.
bigjohnsonzc
Jan 30, 2022 09:27 AM
Sassypaints
Aug 10, 2019 03:32 PM
mb1096
Apr 12, 2014 11:35 AM
clockmaker
Aug 18, 2012 06:22 PM
blloyd
Jul 30, 2008 08:06 AM
