Sponsored by: Real Truck
01 7.3 auto tranny problems
Old Aug 6, 2017 | 11:22 PM
Will Dale's Avatar
Will Dale
Sticks in first gear unless you let off accelerator around 2000 rpm. Wont stay in overdrive under a load. (Kicks into neutral) had scanner hooked up and shows tc unlocking in od under load. Abs light is on and vss code comes up on scanner. Tranny isnt slipping at all. Haul 10,000lb loads often in montana mountains with overdive off no prob. Has acted like this over a year. Bought truck from owner who said Transmission was rebuilt aprox 100,000 miles ago...
Old Aug 7, 2017 | 09:15 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The first thing to do is fix the VSS code. That can cause all of your problems.
Old Aug 7, 2017 | 09:34 PM
Will Dale's Avatar
Will Dale
I swapped the vss on rear diff with a good one from my buddys truck and its doing the same thing. Anything else i can check?
E55 Bulldog
Mar 22, 2016 10:03 AM
jeffsk7
Mar 16, 2009 11:28 PM
bigolfordtruck
Jun 4, 2006 09:19 PM
rnlreger2003
1997 - 2003 F150
Dec 20, 2004 06:58 PM
Ironruffy
Feb 24, 2002 08:47 PM
