2015 F250 6.2L No climate control in remote start options
Just bought the truck and when remote starting it i noticed it is turning on the heat. Having read a bunch of different posts it sounds like the climate control would be set to automatic which i would like to have it just use were i set my controls. Problem is i do not have any options on the instrument cluster for climate control and no auto button the the heater controls themselves. I would think that means i do not have automatic climate control but it is doing it. Anyone have any idea how to turn it off?
On my 2011, in the winter I set the heater to the temp I want and set the blower settings before I shut off the truck.
Ssme with the a/c - I set the temp and blower controls to what I want them to be before I shut off the truck.
I do have "auto" settings, but I don't use it.
Always works to the settings I left it at when I shut the truck off when I start it with the remote.
It does take awhile to cool the truck down with the a/c though. If it's hot out, and you remote start it, it will probably not start to cool for a few minutes at least.
It's my understanding (from other posts on this site) that the HVAC settings during the remote start operation are determined by the outside temperature sensor. If the truck's sensor detects that it's cold outside, it turns on the heat. If it detects it's warm, it turns on the A/C. When you turn the key, the HVAC switches to whatever mode you had it in when you last drove. This may be the opposite of what the computer had determined above. Therefore, I'd first check your outside temperature sensor. Does the truck have the correct outside temperature displayed when you start it? If not, this could be causing your problem. If I recall correctly, the thermometer unit is located in the passenger side mirror. It sounds like the computer is detecting the wrong outside temperature.
Hope this helps.
Best,
Dan
Hope this helps.
Best,
Dan
Hope this helps.
Best,
Dan
Hope this helps.
Best,
Dan
If you can get your hands on a OBD II reader and Forscan, you can look at what that temp sensor is reporting - as Dan said - it could be bad or potentially got unplugged/loose connection.
Thanks for the input so far guys. Been researching and logic pointed me to the Ambient temp sensor and sure enough the truck states on the instrument cluster that it is -40F. I am checking now if my Toruqe pro app has a pid that reads the same.
Until then, i have read that the ambient temp sensor is in the passenger mirror and that there is a little cover on the underside to take it out. I do not have the cover on mine. Smooth on the bottom. Does that mean it is somewhere else or will i have to take the housing apart?
pr1
11-02-2012 06:34 PM
