The Haynes manual says this requires 17.7 quarts. Replacement says start with 6.5 quarts and then add a half quart at a time and shift through the gears at high idle.
Is this enough fluid to keep every thing lubed and not damage the transmission? Seems like it might not be enough.
I'd go ahead & drain that torque Converter also, get all of that old fluid out, it's not much harder since you'll be under it anyway, your quart count should go on up then but adding fluid slowly & checking it is Best from my experiences. Measure Twice, Cut Once!
