Sponsored by: Real Truck
A/C question
Old Aug 5, 2017 | 05:13 PM
skyking897's Avatar
skyking897
A/C question
2011 F250 SD, is there a common problem with the A/C not working? Truck I'm looking at buying, the a/c does not work, it only blows hot air. I know it could be any one of several things causing it not to work but some makes and models of vehicles have certain recurring problems with a/c. Was wondering if the SD does.
Old Aug 5, 2017 | 06:48 PM
seville009's Avatar
seville009
Check the refrigerant, of course. If it's completely empty, most likely a leaking line. Can check it by recharging it - if there's a leak, you'll hear it hissing out when you run it after charging it.
Old Aug 5, 2017 | 09:13 PM
adman02's Avatar
adman02
2011s seem to have a problem with evaporator cores leaking. You must remove the entire dash to get to it. If that's the problem, it's pricey repair.
Old Aug 6, 2017 | 07:54 PM
skyking897's Avatar
skyking897
Was trying to decide if I should gamble on fixing it myself or have the dealer fix it. Decided to have them do it. Guess that's what it was, the evaporator. When I called the salesman said it would be a couple of days, they had the whole dash out. Good thing I negotiated a deal where they had to fix the A/C. Now I just have to insist on another road test before I accept the truck to make sure nothing else is wrong from them removing the dash.
Old Aug 6, 2017 | 08:12 PM
mapitts66's Avatar
mapitts66
Just had mine replaced 2 weeks ago to the tune of $2300 with a couple of other things. Yes it is an '11.
fruth04
1997 - 2003 F150
May 2, 2006 09:27 PM
Sgt.Sly
Aug 7, 2005 11:51 PM
firstford
Apr 15, 2005 06:28 PM
ralupien
2004 - 2008 F150
13
Jul 2, 2004 01:01 AM
KarlVW
1983 - 2012 Ranger & B-Series
Apr 23, 2004 02:35 PM
