Power Steering Fluid
Old Aug 5, 2017 | 02:13 PM
VMPowerstroke's Avatar
VMPowerstroke
I have a 2002 Ford F350 7.3L, and I'm really really really REALLY low on PSF and I wanted to know if I can use Valvoline ATF for the fluid? Or do I use something else? I need to know asap, I'm going to be hauling cattle very soon.
Old Aug 5, 2017 | 02:44 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Any Mercon V ATF
Old Aug 5, 2017 | 02:52 PM
Firefighter 1406's Avatar
Firefighter 1406
Mike got you taken care of.
Old Aug 6, 2017 | 02:36 AM
pirschwagon's Avatar
pirschwagon
Perhaps a more important question is: Why are you low on Power Steering Fluid? The Brake System depends on PSF to property operate. Or, operate at all if you have none. hauling Cattle I presume is tasking at best. Something to definitely correct prior to using the vehicle.
Old Aug 7, 2017 | 09:16 PM
VMPowerstroke
Hence why I said, "very soon." My 7.3 is not my daily driver. I just went over every fluid and realized I was low on PSF. I didn't have my owners manual in my glove box and I read online that people use ATF for PSF. I was just skeptical.
Old Aug 7, 2017 | 09:30 PM
bigb56's Avatar
bigb56
That's what Ford specs for the hydroboost system, ATF. Not PSF. The hydroboost system provides pressure for both the brake booster and the power steering.
Old Aug 7, 2017 | 09:41 PM
VMPowerstroke
So what's the problem? I used Valvoline MERCON® V ATF. That's what other forums recommended, and it says on the label it's most recommended by Ford owners.
Old Aug 7, 2017 | 10:23 PM
bigb56's Avatar
bigb56
The problem is I mis-read your initial post and I thought you were asking about using PSF. Carry on
EconolineFan
May 25, 2019 04:02 AM
GEugeneS
17
Dec 24, 2016 07:52 AM
Vinford
May 7, 2014 05:56 AM
madcatter33
Apr 14, 2008 10:04 AM
Stangfire
1997 - 2003 F150
Oct 7, 2005 10:18 AM
