Power Steering Fluid Type?
Old May 23, 2019 | 08:42 PM
EconolineFan's Avatar
EconolineFan
The reservoir in my '95 302 powered E150 is a bit low. I might as well remove as much of the old fluid and replace with new. Per the owner's manual:
Use only power steering fluid that meets Ford's spec ESW-M2C33-F, such as Ford Premium Power Steering Fluid, E6AZ-19582-AA or an equivalent Type F ATF with a Ford registration number (an 8-digit number beginning with 2P printed on the fluid container)
I have a nearly full bottle of Mobil 1 synthetic ATF that is Dexron-III/Mercon rated and two quarts of Valvoline MaxLife High Mileage that has the same specs. Could I use either one of these or is Type F crucial? Also, is ATF hydroscopic like brake fluid? The Mobil 1 fluid is new but the bottle was opened a long time ago as I used it as top-off in another vehicle.
Old May 24, 2019 | 04:30 PM
00t444e's Avatar
00t444e
Either one is fine, and as long as you had the cap on the bottle I wouldn't worry about it.
Old May 24, 2019 | 05:41 PM
wirelessengineer's Avatar
wirelessengineer
Type F and Dex/Merc are not compatible. While a lot of people do use transmission fluid in their power steering, I'd be very leery of using a type that isn't compatible with what Ford recommends.
Old May 24, 2019 | 06:09 PM
00t444e's Avatar
00t444e
Power steering pumps aren't that sensitive, all they are is a hydraulic pump, you could use just about any hydraulic fluid in them and they would work fine, as long as its the right viscosity. They don't have clutches in them like a transmission does that requires a certain type of fluid.
Old May 24, 2019 | 08:23 PM
wirelessengineer
Good to know. Thanks.
Old May 25, 2019 | 04:02 AM
JWA's Avatar
JWA
Like many I use whatever ATF I have on hand, try to use something fresh or unopened though. I never leave caps off any fluid bottles but if the foil seal is broken over time moisture creeps in, AFT loving moisture and vice versus.
Its good to be concerned and ask if uncertain about something but in this case its not a super critical requirement.
Trigger
Jan 18, 2025 10:05 AM
rblaine9000
6.4L Power Stroke Diesel
Nov 23, 2013 03:38 PM
madcatter33
Apr 14, 2008 10:04 AM
Dan F 2
1983 - 2012 Ranger & B-Series
May 30, 2006 02:05 PM
Stangfire
1997 - 2003 F150
Oct 7, 2005 10:18 AM
