Engine removal question
Old Aug 5, 2017 | 06:19 AM
ktm4012's Avatar
ktm4012
Guys, I have a question on taking the engine out of my 79 F 250 4x4 with 400. Do you unbolt trans (NP435) at the bellhousing to motor or the 4 bolts where trans bolts to belhousing? Such a basic question but my searches came up empty. Also, how do you keep tranny propped up after engine is taken out? Thanks for any help.
Old Aug 5, 2017 | 08:10 AM
HIO Silver's Avatar
HIO Silver
To remove the engine, unbolt the bellhousing from the engine.
Prop up/support the trans/bell with a jack n dunnage.
Old Aug 5, 2017 | 08:16 AM
FuzzFace2's Avatar
FuzzFace2
Yep that's the way to do it.
Dunnage - you drive a truck? Only place I have heard that used.
Dave ----
Old Aug 5, 2017 | 01:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Ratchet strap across the frame rails, or a floor jack and a 4" or 6" piece of post.
Old Aug 5, 2017 | 07:30 PM
Joel Cassell's Avatar
Joel Cassell
Getting ready to pull my engine as well and install my newly rebuilt 400. I have done some reading about checking the run-out to insure proper alignment between the bellhousing-crankshaft-transmission shaft. Is this important? I have a new clutch, will it be acceptable just to bolt the clutch to the flywheel and install, or do in need to pull the bellhousing and try to measure run-out? Didnt know how important that was with a NP435.
Old Aug 5, 2017 | 11:53 PM
HIO Silver's Avatar
HIO Silver
Dave ----
Back in the day I supervised the loading of my equipment on heavy lift/heavy cargo helicopters and C-141 Starlifters.
Old Aug 6, 2017 | 06:16 AM
gatorfor88's Avatar
gatorfor88
You might have met my ex-wife.
Old Aug 6, 2017 | 06:31 AM
ktm4012's Avatar
ktm4012
You answered my next question. I was wondering how to support trans over the winter while I work on the 400. Thanks.
maestro1024
21
Mar 18, 2013 08:37 PM
Fordgery
17
Jan 4, 2010 07:33 PM
mercman86
General Automotive Discussion
Dec 1, 2009 10:26 AM
94rangerprerunner
4 Cylinder Engines
Dec 13, 2003 08:12 AM
blackcrewcab
Nov 22, 2002 08:06 PM
