Going under the knife
Old Aug 6, 2017 | 04:36 PM
LiquidSteam's Avatar
LiquidSteam
Nice! My truck is so high with a 2 inch level and 35's I can't imagine raising it 4 more inches! I wish I could see a couple of these big lifts in person. Congrats though as the pics look great!
Old Aug 6, 2017 | 04:38 PM
LiquidSteam
Oh also the alignment is off. Go to a dedicated alignment shop and they will fix your steering wheel/alignment no problem.
Old Aug 6, 2017 | 04:53 PM
gpf2ez's Avatar
gpf2ez
Originally Posted by Chris Crews
Is there a way to change the stock tire pressure to let me lower the air to 60 psi and not throw a code?[/i]
Yes, look at the Forscan thread. You can use that software to set the pressure to what you want.
Old Aug 6, 2017 | 05:08 PM
willynilly's Avatar
willynilly
looks like they didnt bother to cut off the excess threads on the rear ubolts. you can leave them like that but it doesnt have nearly as clean of a look as if the excess was cut off. rear sway bar appears they didnt use any drop down bracket to get it close to the original position. since you probly wont ever haul much in the bed i would just remove the rear swaybar altogether. for what your doing with the truck it will serve no purpose
Old Aug 6, 2017 | 05:34 PM
user 474747383's Avatar
user 474747383
Well by looking at the pic I posted in my comment you need to go get it aligned as soon as possible. Sounds like they ran out of time. Can you take a straight down the drivers side, stoop down when taking it so I can see top to bottom. The off center steering wheel you can fix in your drive way.
Old Aug 6, 2017 | 05:51 PM
puckett_jw's Avatar
puckett_jw
Your truck looks great.
Old Aug 6, 2017 | 06:28 PM
Chris Crews's Avatar
Chris Crews
can an alignment shop mess with aftermarket stabilizers? I'm assuming this is how you get the wheel straight or... am I wrong?
Old Aug 6, 2017 | 06:29 PM
Chris Crews
thanks ma. These wheels are a perfect match for this truck! Love them and the offset!! Glad I went with what you do.
Old Aug 6, 2017 | 06:30 PM
Chris Crews
do these trucks need a longer drive shaft?
Old Aug 6, 2017 | 06:31 PM
Chris Crews
Does it sound weird for the truck to pull to the right slightly? Or is this common. Does it have to do with the place the stabilizer that replaced the factory one is located?
Old Aug 6, 2017 | 06:58 PM
user 474747383
need to see it from the front and not from a areal view, Straight on . But nice rear tire
Old Aug 7, 2017 | 08:36 AM
kylant's Avatar
kylant
as I posted in the facebook thread; toyo mts have a known right pull, get your alignment checked/fixed. you need to correct your caster.
like others have said, you can straighten your wheel by adjusting the drag link.
stabilizers have no adjustment and may be contributing to the pull. if there is high pressure in the stabilizer it may produce a pull.
i had a carli stabilizer on my ram and the pressure from it induced a pull.
stewy604
Dec 1, 2017 12:29 PM
NYf250
Aug 16, 2008 11:07 AM
Storm
Apr 6, 2007 10:03 AM
CounterMaker
Feb 16, 2007 03:48 PM
Onespeed24
Dec 23, 2005 05:00 PM
